Murdoch Posted May 20, 2015 Posted May 20, 2015 I have not been able to get the peer pings to work on ps4 playing cod aw using an iPad. Peer ping is ticked. Anyone else having this issue?
Netduma Staff Netduma Crossy Posted May 20, 2015 Netduma Staff Posted May 20, 2015 Have you selected the correct slot for peer ping to work on? There is a drop down box that you must choose from. There are instructions on setting it up on the Wiki
Administrators Netduma Iain Posted May 20, 2015 Administrators Posted May 20, 2015 Can you try Crossys suggestion please Murdoch
Apowell Posted May 20, 2015 Posted May 20, 2015 I am on version 1.03.3 and am not seeing the boxes or anything from Sims video in that other post. right under where it says Geo filter I have auto ping host, kilom, strict mode, show dormant hosts, and show legend. Then zoom factor and filter by distance and ping assist. Where should it be in relation to those?
Administrators Netduma Iain Posted May 20, 2015 Administrators Posted May 20, 2015 Its underneath the map. It should have a title "Peer Ping" and below that is a combo box where you can select the right service
Apowell Posted May 20, 2015 Posted May 20, 2015 i am not playing right now but I went and looked at the whole page and I don't see it. Do I need to have selected a host or dedicated server for it to show up?
Administrators Netduma Iain Posted May 20, 2015 Administrators Posted May 20, 2015 Make sure you have selected "Peer Ping" at the top.
Apowell Posted May 20, 2015 Posted May 20, 2015 I dont see it anywhere. Here is what my page looks like. http://i.imgur.com/OrHBT1J.png http://i.imgur.com/gKwNdLZ.png
Administrators Netduma Iain Posted May 20, 2015 Administrators Posted May 20, 2015 Looks like you need to upgrade mate. Please follow the instructions here: http://wiki.netduma.com/doku.php?id=manual_update
Apowell Posted May 20, 2015 Posted May 20, 2015 Ok thanks. I have hit the upgrade button but it tells me I'm on the most current. I will keep that in mind now. Thanks again.
PharmDawgg Posted May 20, 2015 Posted May 20, 2015 We have got to fix that basic upgrade issue. This has been causing confusion for alot of Netduma users. lol
Apowell Posted May 20, 2015 Posted May 20, 2015 That would be me lol. No worries. Thought I was going crazy when I couldn't see the peer ping but it told me I was current. Upgrade completed and everything is good now. Appreciate it gentlemen!
Administrators Netduma Iain Posted May 20, 2015 Administrators Posted May 20, 2015 Awesome, yes I should change that all basic thing. It is very confusing lol! Here is the new ticket: https://trac.devzing.com/netduma/Duma/ticket/55#trac-add-comment
Dirty Dog Posted May 20, 2015 Posted May 20, 2015 We have got to fix that basic upgrade issue. This has been causing confusion for alot of Netduma users. lol Good point Buck. It's understandable new customers maybe confused if the GUI, is telling people Firmware is up to date.
Murdoch Posted May 20, 2015 Author Posted May 20, 2015 The peer pings started working after a few games. It would only ping two or three players in a game with geofilter on. It pings all with filter off. I was shocked to see a player ping of 900 ms in a game. I will test it out more tonight.
Murdoch Posted May 20, 2015 Author Posted May 20, 2015 However I don't remember seeing this group of ping options?
Administrators Netduma Iain Posted May 20, 2015 Administrators Posted May 20, 2015 Somehow you've got admin mode, those buttons don't work any-more anyway
Murdoch Posted May 20, 2015 Author Posted May 20, 2015 I don't have them, I pulled that screen shot from that other guys video post. So I should not have them, correct?
Administrators Netduma Iain Posted May 20, 2015 Administrators Posted May 20, 2015 Oh my mistake, yes those are for admin mode & don't actually work any-more. It was from way back in January.
seantiticombs Posted May 28, 2015 Posted May 28, 2015 am a little confused with the ping peer what service will i select for the bottom page. am on ps4 with pa. am i going to selelet service 1,2,3 or 4?
Netduma Staff Netduma Crossy Posted May 28, 2015 Netduma Staff Posted May 28, 2015 am a little confused with the ping peer what service will i select for the bottom page. am on ps4 with pa. am i going to selelet service 1,2,3 or 4? Select the slot that the console is in. E.g if you are in the first slot, select 1 from the drop down box, if you are in the second max, set 2 from the drop down box etc.
YOBIGDUSOFLY Posted May 30, 2015 Posted May 30, 2015 Have you selected the correct slot for peer ping to work on? There is a drop down box that you must choose from. There are instructions on setting it up on the Wiki Is peer ping the same as Auto Ping Host?
Netduma Staff Netduma Crossy Posted May 30, 2015 Netduma Staff Posted May 30, 2015 Is peer ping the same as Auto Ping Host? No. Auto-ping automatically pings the host. Peer ping shows a bar chart of the pings to everyone in your lobby
