Seeing packet loss using PingPlotter?
If you are seeing packet loss using PingPlotter i think there maybe a bug with certain two router set up's.
On a windows machine.
Start > run > type cmd > type ....
ping bbc.co.uk -n 25
or
ping twitter.com -n 25
or
ping twitter.co.uk -n 25
-n 25 will ping the server 25 times
Depending on where in the world you live you would pick a .co.uk or a .com URL or I.P
For Apple users
  1. Open Network Utility (located inside Applications > Utilities).
  2. Click Ping.
Then do the above without the -n 25 and enter 25 into the "send only _ pings" instead.
If you see 0 loss then its a PingPlotter bug.
Very cool Yoda and thanks for putting us Mac users in there too... ;)
  • 4 weeks later...
Thank you so much for this, I was seriously going crazy using ping plotter and seeing 50-85% packet loss between the netduma and my at&t modem.
Panic over :)
  • 6 months later...
If you're having trouble with packet loss on ping plotter it's because the duma uses a packet prioritization that drops packets instead of buffering them to reduce bufferbloat (excess ping) It's perfectly normal, no need to freak out :)
