wawaweewaVeryNice Posted January 23, 2017 Posted January 23, 2017 My wifi connection randomly drops out for my whole house it just happened about 10 minutes ago
Administrators Netduma Fraser Posted January 24, 2017 Administrators Posted January 24, 2017 Please try the above and let us know if that resolved it.
wawaweewaVeryNice Posted January 24, 2017 Author Posted January 24, 2017 you did all that in the 1 on 1 that happened with the vpn
Netduma Staff Netduma Jack Posted January 25, 2017 Netduma Staff Posted January 25, 2017 Ok just to check; are there any wireless devices i.e wireless headphones or devices connected via wi-fi in close proximity to the router? If so move them away and see if the issue persists.
wawaweewaVeryNice Posted January 25, 2017 Author Posted January 25, 2017 nope my phone is the only device that is the close to it
wawaweewaVeryNice Posted January 25, 2017 Author Posted January 25, 2017 Now my wifi is slow i should be getting 200 download and im getting 38 on dslr reports
wawaweewaVeryNice Posted January 25, 2017 Author Posted January 25, 2017 My settings of my netduma keep getting altered by itself i dont understand whats going on with it
Netduma Staff Netduma Jack Posted January 26, 2017 Netduma Staff Posted January 26, 2017 My settings of my netduma keep getting altered by itself i dont understand whats going on with it Ok, are the drop-outs still occurring? Try these settings if you haven't already: - Reactive Algorithm - 100% anti-flood - Share excess enabled - Reset device prioritisation & apply - Disable IPv6 in WAN, LAN & misc - Disable deep packet in misc - Enable turbo mode - Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. Also make sure cookies are enabled in settings > misc, and that whenever you reboot you do it from settings > misc to preserve your settings. Are the settings changing while the router is switched on without any reboots etc? Please specify your exact set-up.
wawaweewaVeryNice Posted January 26, 2017 Author Posted January 26, 2017 yeah they occur every few days and my connection still keeps dropping out between 5pm and 8pm gmt The settings were changed when i unplugged the router by the plug. On the xbox it say dhcp server with an error cant quite remeber and on the wireless devices it says obtaining ip address but after a reboot it works again although my brother keeps getting kicked offline while playing games Could it be due to the dhcp? Congestion Control: Reactive 100% 100% share excess i have 4 devices in hyper traffic. VPN: Fine WIFI: WPA-PSK2 Port forwarding: i have it set up for PS4 only UPNP: ENABLED LAN: host address filled DHCP enabled 100 250 12 hours DNS enabled MTU enabled DHCP LEASE PS4 141 XBOX 24 mtu enabled MISC cookies enabled wifi workaround enabled turbo mode enabled My wifi has gone out twice in the last hour but both ethernet cables i am using are still on the internet
Administrators Netduma Fraser Posted January 27, 2017 Administrators Posted January 27, 2017 Don't unplug the router, that will cause settings to reset which is why you're having that problem. If you need to reboot then do so from settings > miscellaneous. What devices do you have in hyper traffic? It should only be consoles. Nothing with high intensity traffic should be included otherwise it could cause issues. You shouldn't have port forwarding & UPnP enabled as this could cause conflicts. If you think it may be DHCP then set a static IP for every device in DHCP lease and see if the dropouts stop. You won't get 200 out of the WiFi by the way.
wawaweewaVeryNice Posted January 27, 2017 Author Posted January 27, 2017 I know im not getting 200 on ethernet im not bothered about that its just that the wifi around my house keeps dropping and everyone is complaining about it since getting the netduma
Administrators Netduma Fraser Posted January 27, 2017 Administrators Posted January 27, 2017 Try the above and see if that helps at all. Otherwise will probably need to be a replacement.
