bridge help
finally figured out how to set my sip router to bridge mode (to act as a modem only) but
after turning on bridge i lose all internet connection, which i think is poss down to username  pass combo.
am i missing something somewhere?
So you have your ISP connected to the Netduma via Ethernet (Port 1 to port 1)? When you connect your Netduma to a PC through a wire, do you have internet access? Can you access the interface?
You need to input the password / username in the PPPoE section of the Netduma interface. What makes you believe those are incorrect?
Yeah where is the ppoe section on the netduma as cant find it
Thnx
Go under Settings>WAN on the Netduma gui. It is at the top of the page.
Now i look stupid, put details in wan section and it wirked instantly.
Also noticed an immediate improvement in game as previously i could not vote for a map between games screen would just hang until next game started ( if that makes sense) but now its working spot on.
One more issue i have now is that i cant log into isp router using default ip address anymore, im assuming its ip has been changed from default and i dont know how to find it.
Otherwise thnx a bunch
nah doesn't work :(
Hey, just wanted to see if you've got it working; we're here to help you out if you need it.
  • 2 weeks later...
