loopylinney Posted December 31, 2016 Posted December 31, 2016 I am having some connection issues with my netduma, I connected then netduma directly to my router and my Xbox will connect fine to the netduma then after around 10 minutes it would disconnect, I then tried connecting my netduma to my wifi extender but that just made it even worse, please help asap
Zennon Posted December 31, 2016 Posted December 31, 2016 Untick Enable WiFi work-around in misc settings of the duma if you are trying WiFi, even better wire your console with Ethernet cable directly.
loopylinney Posted December 31, 2016 Author Posted December 31, 2016 that was unticked already, I am not able to connect my console directly to the router, this is why I bought the net duma was so that I didn't have to connect to it straight from wire.
loopylinney Posted December 31, 2016 Author Posted December 31, 2016 Untick Enable WiFi work-around in misc settings of the duma if you are trying WiFi, even better wire your console with Ethernet cable directly. that was unticked already, I am not able to connect my console directly to the router, this is why I bought the net duma was so that I didn't have to connect to it straight from wire. there is also no way I can connect my console wired straight to the router as I the router is on ground floor and I am on the first floor
Zennon Posted December 31, 2016 Posted December 31, 2016 Then please tick the WiFi workaround reboot the duma from misc settings reboot and try that If that does not work try the WiFi security mode WPA2-PSK. Also check the WiFi channel is not congested Here
loopylinney Posted December 31, 2016 Author Posted December 31, 2016 does it matter that the duma is connected to the wifi extender instead if the actual router???
Administrators Netduma Fraser Posted December 31, 2016 Administrators Posted December 31, 2016 That should be fine as long as it's connected properly, just make sure to follow the above
loopylinney Posted December 31, 2016 Author Posted December 31, 2016 thank you fraser and zennon, I will see if this works
loopylinney Posted December 31, 2016 Author Posted December 31, 2016 I am still getting random lag spikes now in modern warfare remastered and infinite warfare
ColonicBoom Posted December 31, 2016 Posted December 31, 2016 I am still getting random lag spikes now in modern warfare remastered and infinite warfare On the Netduma graph, on Ping Plotter, or you can just see visible lag spikes in game?
loopylinney Posted December 31, 2016 Author Posted December 31, 2016 On the Netduma graph, on Ping Plotter, or you can just see visible lag spikes in game? they are visable in game lag spikes
Administrators Netduma Fraser Posted January 1, 2017 Administrators Posted January 1, 2017 Can you provide the screenshots asked for in this guide please http://support.netduma.com/support/solutions/articles/16000022425-lag-support-instructions-to-post-on-the-forum-
