Control panel, for gods sake!!!!
Seriously, what the hell is wrong with the control panel, are you guys doing something to it testing the new one or what, as slow as a a sloth on pause. Tried everything to sort it, getting to a point it can't even be used.
Yeah I don't know, had mine since launch 2014 and I never had a slow gui issue, or any problems actually... No slow speeds, no slow gui, no port forwarding issues, no wifi problems, no rebooting issues, etc. The only problem I had with it, wasn't even the router's fault. Which leads me to believe that 99% of the problems are user error or sheer laziness to read the wealth of information out there about setting this up.
If yours is slow you either didn't read this:
http://forum.netduma.com/topic/19266-slow-gui-interface-the-solution-is-here/?do=findComment&comment=131792
Or you have some kind of pop-up/script blocker running, an anti-virus/malware/etc running which is blocking it.
No issues with my gui. I use hyper lane, upnp, host filtering. Set up for 2 xb1. What browser are you using?
Just a thought, try turning off Ad Blocker on the page for the Duma UI if you have it enabled....For some reason that worked a treat for me haha sped it up instantly :)
This also helps to resolve the can't ping issue if anyone experiences it.
