Question about Optimization Guide
Sorry if this is already somewhere in the forum or guides and I missed it.
Should I be following the guidelines for my expected/ paid for speeds in setting up my netduma or the speeds I actually get even when testing multiple times connected directly to my modem? Upon calling my ISP they reminded me that my "paid for speeds" are best case scenarios.
Anyways the settings vary depending upon which I implement.
I always set mine based on actual ('best' actual, rather than average). But I never put in what I pay for because I get nowhere near it.
I pay for 80/12 or something like that but I usually only get 25/6 (ish), sometimes get 28/7 so I set mine at 28/7.
I put in slightly less than I actually get. I get 28-7 so I input 27-6
Then use 80% cc each way
I pay for UP TO 200Mbps but I get 240/12, when on paper I should be getting up to 200 down and only 10 up...
So you configure your router to the speeds you normally get before you had the Netduma
