bagsta69 Posted November 18, 2016 Posted November 18, 2016 OK yall, So I have a PS4 Pro which uses HDMI 2 cables to send information to my 4K 2160p / 60 TV. This was all working fine kicking out some seriously great images. Now when I introduce the Elgato HD60 capture device into the mix running HDMI 2 cables to monitor and on the pass through to tv the resolution drops to 1080P as this is all the Elgato is capable of recording at. So, I figured that if I could buy a HDMI splitter I could send a 2160P image straight to my TV and have the other signal go through the Elgato at 1080p. However, I have been searching for over an hour now on the interweb trying to find a splitter that is HDMI 2 compliant but they all appear to be HDMI 1.4. Would a 1.4 compliant splitter work or should I really continue my search for a HDMI 2 compliant splitter? Also if anybody knows where I can get my hands on one please feel free to let me know. Cheers.
II N3MES1S II Posted November 18, 2016 Posted November 18, 2016 Here ya go https://www.amazon.com/Orei-Splitter-Ports-Supports-Control/dp/B016O5NMMC
bagsta69 Posted November 18, 2016 Author Posted November 18, 2016 HOLY ****, I searched for fekking ages and found nowt but 1.4 boxes. You are a star Thanks
bagsta69 Posted November 18, 2016 Author Posted November 18, 2016 AH, "Works with all HDMI 1.3 and 1.4: Supports 3D andLPCM,Dolby-AC3, DTS7.1, DSD/Dolby TrueHD/DTS-HD master audio, Essentially all available audio options are supported " HDMI 1.3 and 1.4 I think Im going to need HDMI 2 which is where my problem has been. Found loads supporting 1.4 but none that support HDMI 2
II N3MES1S II Posted November 18, 2016 Posted November 18, 2016 AH, "Works with all HDMI 1.3 and 1.4: Supports 3D andLPCM,Dolby-AC3, DTS7.1, DSD/Dolby TrueHD/DTS-HD master audio, Essentially all available audio options are supported " HDMI 1.3 and 1.4 I think Im going to need HDMI 2 which is where my problem has been. Found loads supporting 1.4 but none that support HDMI 2 1 input (1 Source) to 2 Output ( 2 Display) Supports HDMI 2.0 with EDID
RADDY1993 Posted November 18, 2016 Posted November 18, 2016 OK yall, So I have a PS4 Pro which uses HDMI 2 cables to send information to my 4K 2160p / 60 TV. This was all working fine kicking out some seriously great images. Now when I introduce the Elgato HD60 capture device into the mix running HDMI 2 cables to monitor and on the pass through to tv the resolution drops to 1080P as this is all the Elgato is capable of recording at. So, I figured that if I could buy a HDMI splitter I could send a 2160P image straight to my TV and have the other signal go through the Elgato at 1080p. However, I have been searching for over an hour now on the interweb trying to find a splitter that is HDMI 2 compliant but they all appear to be HDMI 1.4. Would a 1.4 compliant splitter work or should I really continue my search for a HDMI 2 compliant splitter? Also if anybody knows where I can get my hands on one please feel free to let me know. Cheers. Check this out Bags https://www.lindy.co.uk/audio-video-c2/splitters-c159/hdmi-c162/2-port-4k-hdmi-2-0-uhd-splitter-p9147 and underneath that one are 3-8 port ones also
bagsta69 Posted November 18, 2016 Author Posted November 18, 2016 It would appear I am out of luck, The PlayStation 4 Pro (PS4 Pro) was released on November 10, 2016.The PS4 Pro offers output at up to 4K resolutions (3840 x 2160).The PS4 Pro also offers HDR color output as an option. Elgato Gaming Devices Can't Use 4K Video or HDR Colors Elgato Gaming devices cannot passthrough, capture or stream 4K or HDR video.Thus, if you want to use the PlayStation 4 Pro with an Elgato Gaming device, you must set it to output 1080p or less, with HDR turned off. You should also turn off HDCP. All the devices I have looked at that split the signal do so at the lowest rated device. So they do not split the signal and send one at 1080p to the elgato and the other 3840x2160 to the tv. They both are split at 1080p.
Dillinger Posted November 18, 2016 Posted November 18, 2016 Late to the party but I was going to say I saw a tweet awhile back about the lack of support for 4K on recording capture and it wasn't just for ElGato. Bagsta is just too far on the bleeding edge - you trend setter you.
bagsta69 Posted November 18, 2016 Author Posted November 18, 2016 Bagsta is just too far on the bleeding edge - you trend setter you. Don't you swear at me young man. lol
MrRelentlessUK Posted November 18, 2016 Posted November 18, 2016 WHAAATTT!!! I just brought a 4K monitor for the Pro mate, But use the Elgato pro! I'd be happy to stream/record at 1080p or less as long as my eyes are seeing 2160p!
bagsta69 Posted November 19, 2016 Author Posted November 19, 2016 Yeah Im a bit disappointed myself mate.
antithesis Posted November 19, 2016 Posted November 19, 2016 You'll need to wait until a compatible HDMI splitter pops up. One output to 4K TV, the other to the Elgato. New gear should show up on Amazon soon enough.
bagsta69 Posted November 19, 2016 Author Posted November 19, 2016 I have a few questions gone out to a few suppliers to see if there devices are capable of doing this using EDID, I will update as soon as I know. The only other way I can think of doing it is to install a downscaler. https://sewelldirect.com/hdmi-to-hdmi-4kx2k-scaler-converter-
adel75 Posted November 23, 2016 Posted November 23, 2016 Late to the party but I was going to say I saw a tweet awhile back about the lack of support for 4K on recording capture and it wasn't just for ElGato. Bagsta is just too far on the bleeding edge - you trend setter you. It would appear I am out of luck, The PlayStation 4 Pro (PS4 Pro) was released on November 10, 2016. The PS4 Pro offers output at up to 4K resolutions (3840 x 2160). The PS4 Pro also offers HDR color output as an option. Elgato Gaming Devices Can't Use 4K Video or HDR Colors Elgato Gaming devices cannot passthrough, capture or stream 4K or HDR video. Thus, if you want to use the PlayStation 4 Pro with an Elgato Gaming device, you must set it to output 1080p or less, with HDR turned off. You should also turn off HDCP. All the devices I have looked at that split the signal do so at the lowest rated device. So they do not split the signal and send one at 1080p to the elgato and the other 3840x2160 to the tv. They both are split at 1080p. you need a magewell Pro capture 4K plus to do that.. http://www.magewell.com/pro-capture-hdmi-4k-plusand a PC to capture at 4K or this 70$ 4K to 1080p downscaler to insert between the hdmi splitter and the elgato https://www.amazon.com/Sewell-Upscaler-Downscaler-output-resolution/dp/B01K5I9BQK/ref=sr_1_1?ie=UTF8&qid=1479903750&sr=8-1&keywords=4K+1080p+downscaler
bagsta69 Posted November 23, 2016 Author Posted November 23, 2016 Cheers, I thought the downscale would work. Just need to see if I can find one in the uk, still quite expensive option though
Israeli Falafel Posted November 24, 2016 Posted November 24, 2016 If you are using VR, that inline with the PS4 PRO it also doesn't support 2.0. Hopefully they will come out with a patch for it.
II N3MES1S II Posted November 25, 2016 Posted November 25, 2016 I did a little more searching but only found this but it seems to be the type of device you need. http://www.hdtvsupply.com/1x2-hdmi-splitter-scaler.html?ref=lexity&_vs=google&_vm=productsearch&gclid=CLSZkPmLxdACFUtNfgodXPQDyw
abc123 Posted November 26, 2016 Posted November 26, 2016 A splitter won't work in this scenario, the el gato cannot read anything above a 1080p image. So if you split the 4k image it will just be showing a black screen for the el gato. this is the same for all capture devices (they need the image coming in to be the same as what they support). I'm sure a blackmagic card exists that can do 4k but it will cost $3000 It will take time for capture card support of 4k
bagsta69 Posted November 26, 2016 Author Posted November 26, 2016 A splitter won't work in this scenario, the el gato cannot read anything above a 1080p image. So if you split the 4k image it will just be showing a black screen for the el gato. this is the same for all capture devices (they need the image coming in to be the same as what they support). I'm sure a blackmagic card exists that can do 4k but it will cost $3000 It will take time for capture card support of 4k Hence the downscaler after the splitter to downscale the image to 1080p before it goes to the Elgato, I'm pretty sure it would work.Still expensive though.
adel75 Posted December 2, 2016 Posted December 2, 2016 A splitter won't work in this scenario, the el gato cannot read anything above a 1080p image. So if you split the 4k image it will just be showing a black screen for the el gato. this is the same for all capture devices (they need the image coming in to be the same as what they support). I'm sure a blackmagic card exists that can do 4k but it will cost $3000 It will take time for capture card support of 4k i think you missed my post. you can do it for less than 1k$ in 4K or for 70$ if you only need to capture a downscaled 1080p of your 4K games while still playing ta 4K.
abc123 Posted December 2, 2016 Posted December 2, 2016 i think you missed my post. you can do it for less than 1k$ in 4K or for 70$ if you only need to capture a downscaled 1080p of your 4K games while still playing ta 4K. correct, a downscaler would be required. the linked one only does: Input resolutions: 480i to 4Kx2K@30Hz the PS4 Pro does 4Kx2K@60Hz so i'm sure there is another device and you are correct, a splitter to a downscaler to the cap card and the other end of the splitter to the tv would work. ---->Downscaler-------->Capture Card PS4 Pro ---->HDMI Splitter---| ---->TV (4Kx2K@60Hz)
