Lena Posted November 8, 2016 Posted November 8, 2016 I've read the solution somewhere before but I can't find it. Someone please post it again. Thx!
AnonymousBleach Posted November 8, 2016 Posted November 8, 2016 I've read the solution somewhere before but I can't find it. Someone please post it again. Thx! To my knowledge, this is correct. you should see around 40% drop in your bandwidth. There are some tweaks you can do, but you will not get your full ISP bandwidth once using a third party device.
Yam Yam Posted November 8, 2016 Posted November 8, 2016 To my knowledge, this is correct. you should see around 40% drop in your bandwidth. There are some tweaks you can do, but you will not get your full ISP bandwidth once using a third party device. Thats not true at all, you will only see a drop in bandwidth if you decrease the CC sliders or don't have it setup correctly. I've read the solution somewhere before but I can't find it. Someone please post it again. Thx! Its posted many times around the forum but the best place is on the home page called 'Knowledge Base' Here's the speed help section: http://forum.netduma.com/forum/51-getting-full-speeds/ I'm on 152/10 but with the Duma I get 165/11.5 max
Lena Posted November 8, 2016 Author Posted November 8, 2016 Thanks but that's not what I'm looking for. I think it was the admin's post about ticking and unticking boxes
PharmDawgg Posted November 8, 2016 Posted November 8, 2016 Hope this helps. Reactive Algorithm 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Enable turbo mode for speeds up to 300mbps Enable super turbo mode for speeds up to 999mbps Both turbo and super turbo have to be selected for super turbo to work. Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. Do a wired speed test from a PC
Administrators Netduma Fraser Posted November 9, 2016 Administrators Posted November 9, 2016 Buck's advice should get you sorted!
Lena Posted November 9, 2016 Author Posted November 9, 2016 100% anti-floodShare excess enabled Where can I find this two?
Slipknot31286sic6 Posted November 10, 2016 Posted November 10, 2016 Congestion control tab on left 3rd one
Lena Posted November 10, 2016 Author Posted November 10, 2016 Thank you so much everyone! I pay for 1GB and I used to get around 40mb down but now I get around 450mb!
Administrators Netduma Fraser Posted November 10, 2016 Administrators Posted November 10, 2016 Great to hear that! You should be able to squeeze a bit more out of it depending on the server you're using to test.
Slipknot31286sic6 Posted November 10, 2016 Posted November 10, 2016 To see if u are getting full speed downloads check out Firefox add on downloadthemall go to Microsoft site and download visual basic. I downloaded 4 gigs at 25MB per sec in 3 mins.
Lena Posted November 10, 2016 Author Posted November 10, 2016 LOL This was during 12 in the midnight which has little traffic. I think it's my ISP. It's time to find a new one. What a fucking joke
Netduma Staff Netduma Jack Posted November 10, 2016 Netduma Staff Posted November 10, 2016 If your settings are exactly what Buck said, then it's looking very likely that your ISP isn't getting you the speeds you're paying for. Perhaps try another ethernet cable, other ports in the router, and try doing speed tests at different times in the day. (Even though you did one at a good time). You need to make sure you've ruled out every option before you go to your ISP. Also, what speeds do you get by running a speed test wired into your ISP hub? That's probably the best way to rule out the Netduma; it'll always be a higher number, but if it's not much higher then your ISP is at fault. Let us know how you get on
