Trueseeker Posted April 18, 2015 Author Posted April 18, 2015 How do you set up netgear nighthawk r7000 to NetDumar router?
cranium2001 Posted April 18, 2015 Posted April 18, 2015 Modem-router-netduma-system. Make sure you dmz in the advanced settings on netgear.
Trueseeker Posted April 18, 2015 Author Posted April 18, 2015 Didn't see the blue box to put netdumar into DMZ, I have Internet through box routers but could not connect to servers. Where do I go on router to open dmz
Alex49H Posted April 18, 2015 Posted April 18, 2015 Yeah for some reason that box doesn't appear for some of us in the Device Manager. But in my case I still have an open Nat.
cranium2001 Posted April 18, 2015 Posted April 18, 2015 Didn't see the blue box to put netdumar into DMZ, I have Internet through box routers but could not connect to servers. Where do I go on router to open dmz I would reboot modem and move on down the line one at a time rebooting. I had an open nat as well but did it anyway.
Trueseeker Posted April 19, 2015 Author Posted April 19, 2015 Saw the blue message, told me to use WAN IP and went into my netgear router and place use that to put into DMZ. I rebooted everything and I have issues getting olive to play, says servers for AW down. I also having issue keeping playstation online. I get to play for a little bit then everything online freezes and have to close application. Anyone else having issues?
cranium2001 Posted April 19, 2015 Posted April 19, 2015 Make sure you have strict ticked and that your mac address didn't change. Mine changed a few times. Sometimes the reboot order matters for me. Reboot one at a time in the same order. Is nat type open?
Zennon Posted April 19, 2015 Posted April 19, 2015 If you are still having connection woes you should follow the guide Iain said you should look at ....http://wiki.netduma.com/doku.php?id=lag_support_instructionsand do a Internet DiagnosisPost the results to rule out a ISP issue before we can move on
Guest Netduma_Iain Posted April 19, 2015 Posted April 19, 2015 Could you finish the tour off, that will get you a basic setup of the router. Once done, just leave your router switched on. Then it shouldn't appear again. If you don't see a blue box in device manager that means your connected to a modem so you don't need to do DMZ stuff. Your NAT should be open. I can't help you without a screenshot of your entire host filtering page while gaming. Once you do that I can suggest what to do from there. Thanks
