Geo Filter On/Off problem
Hey guys,
I have noticed a problem with the geo filter, when I disable the the geo filter to go into a private game I still get the yellow triangle and will not be able to connect to the host. even if I cover the host (after disabling) It will still appear as a yellow triangle and block the connection. I have tried to allow the host but still unable to connect. I can get around this problem by keeping the geo filter enabled all the time and just cover the host when I need to connect to them and shrink it down when playing pubs. as I said it only happens when enabling and disabling the filter. Just thought it is a bug and could be fixed?
EDIT: even after leaving geo on and expanding It will still not allow me to join.
Thanks guys :).
Are you waiting 2 minutes?
Sometimes I have to re start bops after waiting more than two minutes.
yeah man after waiting it still wont allow me to, I could restart bops and see if that sorts it but its not ideal lol.
I go to games and start a new game up then immediately restart bops that sorts it.
Had a whirl on ghosts for a change before geo over the UK and Ireland, no games found widened to the whole of Europe, nothing.
Turned off the geo filter, nothing.
Waited well over two minutes still nothing, restarted the game and I could join lobbies there is a bug it seems.
This happens on Star Wars also.
.6
Happens to me too, I think turning it on and off so much messed with it. In the end the only thing that fixes it is restarting the router for me.
Yeah I found restarting the router does the trick to mod.
It has to be a bug I am sure Iain didn't intend for it to be like this lol.
Zen could you inform Fraser about the possible issue?
Thanks for your input guys :).
I have edited the title so Fraser will see it when he checks the threads.
After waiting 2 minutes does is it still appear on the map as a caution triangle or does everything disappear and then when you try connecting it shows up as blocked even when disabled?
It seems so yeah Fraser, I will try again tonight to double check the issue but that is what as been appearing to happen.
Will post back as soon as I have double checked save wasting time looking into it if I am just being a retard here xD.
Pro when you turn off the geo filter refresh the host page on the Duma.
It has worked for me tonight doing so.
I loaded star wars and forgot to take the geo off, so i unticked enable, refreshed and found a game right away.
My issue maybe that I am on my phone when I enable/disable and i think the page is not refreshing its self correctly using safari/iphone.
