NETDUMA WILL NOT WORK PLEASE HELP!!!!
My netduma had been working fine then one day it just stopped. I tried everything resetting the setting, even a factory reset and it still won't work. I can log into it but there is no wifi/connection at all it says I'm on the netduma wifi but there is no connection.
Hi, is your Netduma plugged into a hub/modem? Could that be causing you issues maybe try restarting that.
- Tom
Make sure you have plugged your hub/modem in to port 1 on the Netduma.
Go to Settings > WAN and make sure static is disabled.
Then turn off the R1 and turn off your ISP hub. Wait 10 seconds then turn on your ISP hub. Wait 30 seconds then turn on the R1.
Is the wifi broadcasting ?
The wifi password is now netdumar1 after a factory reset.
I am using one from Verizon fios. And as far as wifi broadcasting I'm not sure what that means but I can sign into the wifi and it shows that I am connected but I can't do anything on it. There is no connection.
When connected to the Wifi, can you access the dashboard from 192.168.88.1?
Like router, a Verizon fios one if you mean something else by modem then please tell me cuz I'm not sure what that is.
Let's see try this.  We know you have the Duma R1.  What is/are the name(s) and model number(s) of any gear given to you by your service provider (not including a cable box, DVR, etc).
And then
Is there anything else hooked up with the Netduma and the gear from your CATV or ISP other than your gaming consoles (like switches, powered line adapters, etc)?
