lKoNviiCt Posted February 9, 2016 Posted February 9, 2016 i did the Auto-Setup and it say Would you like the router automatically configured to handle your speeds then i click yes and it come Warning update bandwidth not working
e38BimmerFN Posted February 9, 2016 Posted February 9, 2016 Try a full factory reset from the UI, then set up from scratch.
Habylab Posted February 9, 2016 Posted February 9, 2016 i did the Auto-Setup and it say Would you like the router automatically configured to handle your speeds then i click yes and it come Warning update bandwidth not working I've had this, but have found my IPv6 settings and turbo mode have been turned on and off respectively. I think it is some weird bug, for now. Just do a speed test and you should be away.
lKoNviiCt Posted February 9, 2016 Author Posted February 9, 2016 this upgrade broken and Enable cookies do not work properly need a pach for this netduma team
lKoNviiCt Posted February 9, 2016 Author Posted February 9, 2016 I've had this, but have found my IPv6 settings and turbo mode have been turned on and off respectively. I think it is some weird bug, for now. Just do a speed test and you should be away. still do not work going back to the old version 1.03.5 this new upgrade broken
e38BimmerFN Posted February 9, 2016 Posted February 9, 2016 I found the Auto enables Turbo mode which does work and speeds were good, however Turbo breaks my Microcell so I disabled Turbo and just input manual ISP speed values and when it asks if you want Auto Speed, say NO. .6 working for me other wise. I did a full factory reset and set up from scratch.
Asentrix Posted February 9, 2016 Posted February 9, 2016 i did the Auto-Setup and it say Would you like the router automatically configured to handle your speeds then i click yes and it come Warning update bandwidth not working The warning comes up for myself as well. Are your speeds pretty slow-ish? My speeds 13/1 , update isn't broken , but it will have bugs.
lKoNviiCt Posted February 9, 2016 Author Posted February 9, 2016 no im not on slow speed i get 200 up and 1gb down
opa Posted February 9, 2016 Posted February 9, 2016 The warning comes up for myself as well. Are your speeds pretty slow-ish? My speeds 13/1 , update isn't broken , but it will have bugs. my speeds where slow on previous update and they increased a little but still not receiving near my full potential. i'm suppose to receive 100 down and 10 up well I receive 50 down 10 up
lKoNviiCt Posted February 10, 2016 Author Posted February 10, 2016 Try a full factory reset from the UI, then set up from scratch. still come up Warning
lKoNviiCt Posted February 10, 2016 Author Posted February 10, 2016 i need some help from netduma admin team it won't let me put my right bandwidth in and keep reset everything i have factory reset 5 time today still not working
Administrators Netduma Fraser Posted February 10, 2016 Administrators Posted February 10, 2016 What bandwidth numbers are you putting in? After accepting auto speed setup what speeds are you getting? Cookies works for small settings such as Geo-filter changes.
lKoNviiCt Posted February 10, 2016 Author Posted February 10, 2016 What bandwidth numbers are you putting in? After accepting auto speed setup what speeds are you getting? Cookies works for small settings such as Geo-filter changes. im put in 210.85mbps on the upload and the download on 1080.20 but it still come up Warning
lKoNviiCt Posted February 10, 2016 Author Posted February 10, 2016 gone back to the old version 1.03.5
Administrators Netduma Fraser Posted February 10, 2016 Administrators Posted February 10, 2016 I'm not sure if you are able to put in more than 1000, that could be the issue there. Wouldn't recommend downgrading as we can help you on an outdated version.
lKoNviiCt Posted February 10, 2016 Author Posted February 10, 2016 some netcode was not working on the neduma R1
lKoNviiCt Posted February 10, 2016 Author Posted February 10, 2016 resolve the net code problem on my netduma for the bandwidth
Zennon Posted February 10, 2016 Posted February 10, 2016 resolve the net code problem on my netduma for the bandwidth Manners.
Administrators Netduma Fraser Posted February 11, 2016 Administrators Posted February 11, 2016 Put in 1000 exactly or 999 and see if auto setup then works please
lKoNviiCt Posted February 15, 2016 Author Posted February 15, 2016 Put in 1000 exactly or 999 and see if auto setup then works please cheer pal that work everything on point thank again can you now close this thread cheer
Netduma Staff Netduma Crossy Posted February 15, 2016 Netduma Staff Posted February 15, 2016 cheer pal that work everything on point thank again can you now close this thread cheer Thread closed
