ItsIVIarcus Posted February 3, 2016 Posted February 3, 2016 Hey Guys I Need Best Settings For Netduma R1 For Black Ops 3 On Xbox one, I Hope Someone Can Help Me
secretface Posted February 3, 2016 Posted February 3, 2016 where are you and what is your internet speed?
ItsIVIarcus Posted February 3, 2016 Author Posted February 3, 2016 where are you and what is your internet speed? I live in Manchester in the uk and my internet speed is 55 download 16 upload
Zennon Posted February 3, 2016 Posted February 3, 2016 Put your speeds into the congestion control, set the up and down sliders to 70%. Cover the uk and Ireland with with the geo. That will get you the Irish azure server which plays well.
kizvandutch Posted March 1, 2016 Posted March 1, 2016 I would use dsl reports to test usury connection. Everybody has different connections. Lan is a must!
Paulwall Posted April 21, 2016 Posted April 21, 2016 Hey guys and girls had netduma for about 3 months and still cant get a decent game on bo3 i get the odd 1 or 2 but for most part still lag always putting me on server in usa when i live in uk tried putting pa to 0 but cant get a game takes like 10 min to find game put my pa up to 30 and keep putting me on server in usa got strict mode on auto ping host on thats it also when i load up bo3 all the servers used to show up on map now for some reason none show up on map also with pa set to 0 im getting lag spike like 120ms any sugestions
Administrators Netduma Fraser Posted April 21, 2016 Administrators Posted April 21, 2016 Hey guys and girls had netduma for about 3 months and still cant get a decent game on bo3 i get the odd 1 or 2 but for most part still lag always putting me on server in usa when i live in uk tried putting pa to 0 but cant get a game takes like 10 min to find game put my pa up to 30 and keep putting me on server in usa got strict mode on auto ping host on thats it also when i load up bo3 all the servers used to show up on map now for some reason none show up on map also with pa set to 0 im getting lag spike like 120ms any sugestions Hey, welcome to the forum! In future could you please start a new thread for your issue. With PA on, you'll get servers under your limit. If the host has been caught by PA but is in the US then it is mis located. Ensure you have auto&bleeding edge cloud ticked & applied in settings > miscellaneous. Ensure you're also using congestion control correctly. All devices connected to the duma and not your ISP hub, 70/70 anti-flood, put console in hyper traffic as well.
Paulwall Posted April 21, 2016 Posted April 21, 2016 Ok thanks for help will try hyper traffic all other settings are as you have explained
