Speed Problems after new update
Victor-Yout
Hello,
since the new update (1.03.5) i am having problems with internet speed. my settings are all how they should be.
having a 100 mbit down and 40 up connection gives me these wired test results:
turbo & super turbo mode unticked: 38 mbit down&up (setting i should use)
turbo mode on& super turbo unticked: max 10 mbit down& 5 up
turbo&super turbo on: 93 down & 40 up (the result i usually got before update)
so thats my problem, i dont want to use super turbo because i want to have Congestion control. can someone help me?
There is a bug with the device priority, reset both buttons.
This will be fixed in the upcoming firmware.
thank you for the quick answer, which buttons do you mean? reset distribution?
and which settings should i use for now because only super turbo and turbo gives me normal speeds?
it had something to do with the priorisaton, however im still not getting 93 down (getting 80) and its not that stable. hopefully it get fixed in the next update.
but i am still wondering why i get way better wifi results with turbo and super turbo ticked. ticked: ~75 unticked: ~55 . is there a reason for it?
You shouldn't need the turbos on for your connection:
100% sliders
Reactive
Share excess on
Device prio reset and applied
IPv6 off in WAN, LAN & misc
Deep packet off in misc
No reason that I know of why turbo would increase wireless speeds
These are exactly my settings. Thats why i am wondering. I've done several speed test on different servers, always with the result that turbo gives me better speeds at least in wireless
