Taff Posted November 14, 2015 Posted November 14, 2015 next update, throttling that will be a thing of the past,100% speed will work if i understand right.
Ian88 Posted November 15, 2015 Posted November 15, 2015 This 100% works doing the throttle.. Consistent hit detection.. Not getting mowed down by ppl.. This is tested for about 4hrs so it's not a fluke.. But hopefully we will be able to put our speed bk to normal soon.. Not sure if that will happen though.. Isn't it lag compensation that's built into the game the problem? Irreversible?
Mr fncypants Posted November 15, 2015 Posted November 15, 2015 So should I lower my bandwidth? If so to what?
zombitroid Posted November 15, 2015 Posted November 15, 2015 my games was playing crap til i tried this thanks to raddy SORRY IF ITS A LONG POST BUT IT MAY HELP YOU it may or maynot work for you i have a few tips that might help you from reading over post and put it all together could you guys try this for me heres what i think is the most important part i copied these exact settings and game plays great now copy raddys exact setings including his speed test results here they are 28.95 dl and 7.27 up i put 28.95 dl and 7.27 up into my set bandwith in congestion control settings my normal speeds are a lot higher if i use my normal speeds the game plays crap for me i cant get a kill but with raddys setings im getting double kills you need to reboot router for settings to take affect btw set you geofilter to where ever you are i even copied his set distribution i set my ps4 to 17 percent lol click on this link its for raddys settings it says its for uk users but it might work for everyone just put your location where you are if america click america if europe click europe if austraila click australia etc etc hes in england so thats where he set his too same as me i copied every setting he posted includind misc settings also disatribution 17% etc etc here they are they helped me http://forum.netduma...for-uk-updated/ also could you click here http://www.dslreports.com/speedtest and see what readings you get for buffer bloat i actually get an a+ for bufferbloat i think its the upload thats the most important part i think you need at most 4100 kbs to make this game run ok i posted a thread about this here if any one intrested http://forum.netduma.com/topic/7887-please-read-this/ after you copied raddys settings could you click the link for buffer bloat ans see what rating you get for bufferbloat if you dont get an A rating i would increase or decrease the upload or downhload i bit more so you get an A rating http://www.thinkbroadband.com/speedtest.html this site also might help you know if you need to increase either the up load or download individually as you might only have to increase upload and this site give you rating on both so you can see what needs to be increased or decreased try to get an A rating my ping to dedis are around 15 ms to 20 ms average i really realy hope this helps you guys out and any one who views this No problem. I dont mind reading your post. People who cant read your "long" post shoudnt have clicked on this in the first place. Thanks for taking the time to help fellow gamers out man. really appreciate this!
secretface Posted November 15, 2015 Posted November 15, 2015 So should I lower my bandwidth? If so to what? You should try Raddy's settings , they are posted every time he posts at the bottom. Then test your settings at that dsl reports page that kinel posted. You should have an a or a+ for buffer bloat. I tinkered with mine till I got a's on speed and connection. Which put my download at about 70mb. Although it worked just fine at 28.95 mb when I tried it.
Demonic_Sin Posted November 15, 2015 Posted November 15, 2015 Is it possible that no matter what speeds and slider percentage I put it at I get A's?
secretface Posted November 15, 2015 Posted November 15, 2015 Is it possible that no matter what speeds and slider percentage I put it at I get A's? sure can
fuzzy clam Posted November 15, 2015 Posted November 15, 2015 Is it possible that no matter what speeds and slider percentage I put it at I get A's? Maybe but I've never seen it.If I leave my full speed's I get C or D for buffer bloat if i put my sliders to 70 -80 I get an A-A+.This is just my experience your milage may vary.
kinel Posted November 18, 2015 Author Posted November 18, 2015 I think i got a+ somtimes at 100% when i tried the premptive algorythme but using that you cant put in what bandwith you want to try
Ian88 Posted November 19, 2015 Posted November 19, 2015 There is no fix, or miracle cure to this shit.. I've put in 3days worth of gameplay.. And treyarch has crushed the game to fkin bits with lag comp.. Also the spawns are fkin terrible!
