DL speed
Your firmware should be version 1.03.4
Are the following in order, if not try this...
Access your router (i.e. 192.168.88.1), Congestion Control (on left), Anti-Flood (on right) - Algorithim set it as Reactive, Download and Upload Caps set to 100%.
​Where it says Set Bandwidth, click on the bar, where it says Internet Connection set the Download to 150.00 and the Upload to 20.00, click on Update Bandwidth.
​If that fails, you'll need to factory reset your router and then power down both the Netduma and your modem for a couple of minutes, make sure to power them both back on together and start configuring your speed settings, as mentioned above.
**Factory Reset: Click on Settings then click on Miscellaneous, underneath Miscellaneous Actions click on Factory Reset.
When you go to Settings, there is a LAN and WAN sub-section as well as the Miscellaneous sub-section mentioned, disable all references to IPv6, that may help you.
