mitha dirty Posted September 7, 2015 Posted September 7, 2015 OK so I've had this baby for a year now andI've got the Netduma down pat for the most.Here is something I could not find an answer for and have been wondering for a bit what to do.It is known that you get a slower speed going thru your netduma when you do a speed test.The following are my results; (up/dn) PC 124/12 (not thru netduma) Xbox 360 28-35/12 (netduma) Xbox ONE 70-80/12 (netduma) My question is, from the Congestion Control page, when I set my bandwidth, which results would be best to enter?Right now I use 124/12 Could using the lesser results help or hinder anything? Thanks!
PharmDawgg Posted September 7, 2015 Posted September 7, 2015 Netduma wiki says to enter your expected download & upload speed and that you may have to ask your ISP. But what I entered was the maximum results achieved from speedtest.net. It seems to work ok for me.
Zennon Posted September 7, 2015 Posted September 7, 2015 I would also echo using your maximum results from speedtest.net after a few test to a server near you with the congestion control sliders set to 100% while you test.
RADDY1993 Posted September 7, 2015 Posted September 7, 2015 OK so I've had this baby for a year now and I've got the Netduma down pat for the most. Here is something I could not find an answer for and have been wondering for a bit what to do. It is known that you get a slower speed going thru your netduma when you do a speed test. The following are my results; (up/dn) PC 124/12 (not thru netduma) Xbox 360 28-35/12 (netduma) Xbox ONE 70-80/12 (netduma) My question is, from the Congestion Control page, when I set my bandwidth, which results would be best to enter? Right now I use 124/12 Could using the lesser results help or hinder anything? Thanks! I always enter the speed thats going into my main router.
mitha dirty Posted September 7, 2015 Author Posted September 7, 2015 Sounds good to me I'll just leave it be.
Administrators Netduma Fraser Posted September 7, 2015 Administrators Posted September 7, 2015 You should be able to get very close to those speeds using the duma if you have followed the speed guide, am I okay to lock this thread if you are happy with the answers?
