Administrators Netduma Fraser Posted September 4, 2015 Administrators Posted September 4, 2015 Can you try reducing the anti-flood sliders whilst doing this please to see if that helps
FQs19 Posted September 4, 2015 Author Posted September 4, 2015 Hey Fraser, Nothing on my network was on except the PS4 and my macbook to view the R1 pages and my Asus network analyzer. This is what was happening:
Administrators Netduma Fraser Posted September 5, 2015 Administrators Posted September 5, 2015 Connected to the R1 though and downloading with caps not on 100% does the issue persist?
FQs19 Posted September 5, 2015 Author Posted September 5, 2015 I'll try doing that on Monday and show the results.
FQs19 Posted September 6, 2015 Author Posted September 6, 2015 Hey Fraser, Here is my network analyzer and monitor with the sliders at 70% each and Share Excess ticked: and this is when the sliders are at still at 70% but Share Excess is unticked: There's something strange going on.
FQs19 Posted September 6, 2015 Author Posted September 6, 2015 I just increased the sliders to 100% but left Share Excess unticked, this is what I got: You'll notice the previous downloading since I didn't refresh the page. Just wondering why there is such large spikes?
FQs19 Posted September 6, 2015 Author Posted September 6, 2015 Fraser, Am I correct in saying that the sliders set the limit on bandwidth you can take regardless of ticking Share Excess? Because I just did a speed test on Speedof.me and got the same results with the sliders at 70% but ticking and unticking Share Excess. I'm guessing that the sliders will only allow the % set to be taken from your network and the share excess would allow anything connected to the R1 to either use all 70% or just their portion according to Device Prioritization when Share Excess is unticked.
iAmMoDBoX Posted September 6, 2015 Posted September 6, 2015 When you're on the network monitoring page and you switch to a different page it spikes the graph for some reason. Try it out, you'll see. As for the rest of it, that's the PS4. Set your MTU to 1500 in the settings on the ps4. Seemed to help me a bit.
FQs19 Posted September 6, 2015 Author Posted September 6, 2015 I didn't change pages. I had two tabs open, the R1 network monitor and my Asus network analyzer. I just switched back and forth. But yes, I have seen the R1 go nuts when changing internet pages. The PS4 is set for auto MTU and shows 1500 all the time.
Administrators Netduma Fraser Posted September 7, 2015 Administrators Posted September 7, 2015 Fraser, Am I correct in saying that the sliders set the limit on bandwidth you can take regardless of ticking Share Excess? Because I just did a speed test on Speedof.me and got the same results with the sliders at 70% but ticking and unticking Share Excess. I'm guessing that the sliders will only allow the % set to be taken from your network and the share excess would allow anything connected to the R1 to either use all 70% or just their portion according to Device Prioritization when Share Excess is unticked. Yes exactly. Device prioritisation and share excess only apply to the upload direction. It looks as though you're not getting the massive slow down now which is what I would expect from applying anti-flood as your network isn't getting overly congested. Downloads won't go at a steady rate, they will go up and down. It's looking a lot better than before though
FQs19 Posted September 8, 2015 Author Posted September 8, 2015 Thanks for all the help fellas. Just got some great games on CoDAW.
Administrators Netduma Fraser Posted September 8, 2015 Administrators Posted September 8, 2015 Fantastic to hear that, am I okay to close this thread?
Alex49H Posted September 8, 2015 Posted September 8, 2015 Thanks for all the help fellas. Just got some great games on CoDAW. I found your YT page and watched and sub to you Fargle Gargle!
FQs19 Posted September 8, 2015 Author Posted September 8, 2015 Yes Fraser. You can close this thread.
Administrators Netduma Fraser Posted September 8, 2015 Administrators Posted September 8, 2015 Yes Fraser. You can close this thread. Fantastic, anymore issues feel free to make another
