rieder Posted August 21, 2015 Posted August 21, 2015 Just bought the Netduma R1 and I absolutely love the concept. But when I run a speed test I'm only at 60% of my internet's capacity download speed. I've set it up according to the instructions. My ISP modem is a standard Linksys or Cisco modem-router hybrid. I've connected my the Netduma "Poe" to the ISP router's "1" slot. Here's the problem: If I run a speed test when connected directly to the ISP router, I get 95/100 Mbps in download speed, but when I do the same thing with the Netduma connected as explained above, I only get 60 Mbps download speed (ping and upload stays the same). I've done the DMZ thing as suggested in the Netduma settings. Any suggestions on how to fix this, so I can utilize the speed I've paid for? Thx in advance.
iAmMoDBoX Posted August 21, 2015 Posted August 21, 2015 http://forum.netduma.com/forum/51-getting-max-speeds/
lukasz Posted August 21, 2015 Posted August 21, 2015 Make sure you are on lates version http://wiki.netduma.com/doku.php?id=manual_update then follow that http://wiki.netduma.com/doku.php?id=fine_tune_netduma and the do a wired test speed test on wired connectiion
rieder Posted August 21, 2015 Author Posted August 21, 2015 Thx, will check it out. I always do wired tests.
rieder Posted August 21, 2015 Author Posted August 21, 2015 I'm guessing it's the "preemptive/reactive" setting. Thx for your help!
lukasz Posted August 21, 2015 Posted August 21, 2015 Just chose the relevant speed form the second link and then follow up all of the steps. Again just make sure you are on 1.3.04 versio you can check that on the bottom of you routers page if not on that version use first link to upgarde and then follow the second link.
lukasz Posted August 21, 2015 Posted August 21, 2015 Oh my.... I forgot the most important thing welcome to the DUMA ARMY buddy.
Administrators Netduma Iain Posted August 21, 2015 Administrators Posted August 21, 2015 Welcome to the army mate!
iAmMoDBoX Posted August 21, 2015 Posted August 21, 2015 That's the max I've hit so far. Later on with the new update it will max out my connection at ~180Mbps but the router will go to 900+ Mbps
Administrators Netduma Fraser Posted August 21, 2015 Administrators Posted August 21, 2015 Welcome to the forum rieder! Glad to see its all resolved now! As the original issue seems to be resolved I'll close this thread. Feel free to make a new one if needed, you should also make a post in introductions so we can welcome you properly!
