Still pulling hosts out of parameters HELP
Grip
I'm still getting hosts thousands of miles out of my bubble. I've blacklisted them via the slider feature. Also, my ping setting isn't working as I'm getting hosts double the ping I'm setting as the maximum. Any help would be appreciated.
Thanks!
-'Grip
Hi Grip, welcome to the forum :)
Can you follow this guide to see why you are connecting to hosts outside of your GeoFilter: http://wiki.netduma.com/doku.php?id=why_am_i_connecting_to_hosts_outside_that_are_outside_of_my_geofilter
Can you also read this to see what the function of Ping Assist is and how it should work :) http://wiki.netduma.com/doku.php?id=filtering_logic
Hi , the wiki links are great for learning this stuff :) just to add the ping assist is to assist with pings out side of the geo-filter so inside if there is a host with a high ping then you will get a high ping.
It does not cap the ping inside the geo.
If ping assist detects it as being under your ping limit it will allow it through, so say there was a host with 50-100ms ping, if your PA is set at 50ms, PA may detect that host when its on 50ms, even though it may shoot up to around 100ms once connected if that makes sense.
