Storm Posted September 10 Posted September 10 My XR1000v1 router has been updated to firmware version 1.0.3.88_2.1.43 from firmware version 1.0.0.74. Since this update, the first major issue I have expirenced is all devices both randomly and predictably dropping connections over ethernet and wifi at the same time before regaining internet connection. My Galaxy A15 will specifically say "connected without internet." All LED light indicators on the router show solid white with no error lights on the EU2251 Modem. I'm not on fiber or pppoe as my ISP is Spectrum. I have power cycled the modem before the router. All devices have been address reserved with no randomized mac addresses. All IPs and MACs appear to match in the Address Reservation page and Device Manager page with no ghost devices present. The second major issue, is that once QoS has been enabled (unchecking "Disable QoS" in the three line menu) all connections immediately drop briefly. Setting Congestion Control to 'Always' also causes it to behave erratically with speeds falling far below set slider percentages also with potential connection drops. Packet loss, abnornally high ping values flollow. The Connection Benchmark, Xbox speed test, Ookla speed test all show similar results tested with an ethernet connection to an Xbox Series X. When this issue is present, it has been confirmed to me by multiple others in an Xbox live party that my voice becomes broken/laggy. I don't believe this issue is a visual bug. Setting Congestion Control to 'Never' does not fix the issue. Disabling QoS entirely does sometimes fix the issue, but once re-enabled by unchecking the "Disable QoS" box, the issue immdiately returns with all symptoms including an immediate brief connection drop to all devices. Line speed is 1gb download, 40mbps upload. Input speed is 940mbps download, 40mbps upload. This speed input was used without issue on the previous firmware version. Sliders are set to 80% download and upload. These sliders worked fine on the previous firmware version. When updating the XR1000, I did so over a wired connection using the browser UI on Edge. When the first attempt to update was initiated through the update page, it initially failed. I was able to re-access the page, and attempt a second time. This attempt succeeded. Four factory resets (three pinhole and one erase) after the update has not cleared these persistent issues, along with multiple power cycles and UI reboots. I would like to know if this first failed attempt might have caused an issue despite a successful second attempt, or if there is something else wrong.
Administrators Netduma Fraser Posted September 10 Administrators Posted September 10 That's just security fixes so I'm surprised it's had such a profound effect for you as they/we haven't touched DumaOS in that update. Please provide the logs when they next disconnect. What are the speeds you're getting with them set to 80%? What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g R3 in its DMZ, modem/bridge mode. Are ALL devices connected to the R3? 80% may have worked on the previous version but different versions may require different percentages so it's worth testing/fine tuning to find what works better. The first upgrade attempt wouldn't have caused persistent unclearable issues.
Storm Posted September 10 Author Posted September 10 Thank you for the quick reply. I have screenshotted the system logs I believe you were asking for. This is all that it contains despite numerous QoS changes. The modem the XR1000 is connected to is a Spectrum-issued Ubee EU2251. It doesn't have it's own router functions. The speeds seen in Connection Benchmark and third party speed tests show completely erratic low speeds. At 80% CC with 940mbps download and 40mbps upload, it should be 752mbps download and 32mbps upload respectively. It is all over the place in the low multi-hundreds for download and low teens for upload. Previously, if CC acted erratically, I could fix it by reboot or power cycle. Currently, I am able to replicate an all device connection drop just by unchecking "Disable QoS" and again by enabling "Always" in CC. After these changes, the connection will eventually return, but the frequency of further random drops increases. This has never happened before on any previous firmware. All devices hold an active connection to the router. Device Manager has no ghost devices or offline devices. Even when a device was offline in the Device Manager page, QoS has never behaved like this on the previous firmware. Forgive me for any misinterpretation. I have never had an issue of this scale in the 2-3 years I have owned this router.
Storm Posted September 11 Author Posted September 11 Update; I have noticed system logs that I haven't seen before. In these new logs, it's showing internet connected/disconnected and multiple instances of firmware initialized and strange dates while lacking the typical logs that I would normally see when making setting changes.
Administrators Netduma Fraser Posted September 11 Administrators Posted September 11 How often are you running Connection Benchmark as by design you would get disconnected when its running. Could you download the logs from the menu please so then I can see full context/anything leading up to it. Are you using PPPoE, VLAN or IPv6?
