Administrators Netduma Fraser Posted June 16 Administrators Posted June 16 Right click the page > Inspect Element > Console and paste this command: long_rpc_promise("com.netdumasoftware.settings", "remote_access",["true"]) press enter and it should come back with a response. Let me know when it's done and then reply back here from a device connected to the R2 please and we'll attempt a remote upgrade.
jorgelcd Posted June 16 Posted June 16 (edited) I tried to run the command you were envious of, but it seems it wasn't successful. Please attach a screenshot after running the command. I have a PC connected to it; if you need access to it to try something, I can give you access. I just need you to tell me a preferred time in Brasilia so I can assist you. Edited June 16 by jorgelcd Text
Administrators Netduma Fraser Posted June 17 Administrators Posted June 17 Okay let me check with the team on the best way to get access and I'll come back to you
Administrators Netduma Fraser Posted June 18 Administrators Posted June 18 7 hours ago, jorgelcd said: Good evening. Any news regarding access? Do the same process but use this command instead please: duma.RPCHandler.PromiseAsync("com.netdumasoftware.settings", "remote_access","true") I'll have someone monitor the topic so they can try to upgrade you when you say you're accessible. Netduma Jack B 1
jorgelcd Posted June 21 Posted June 21 I was able to execute the command you sent. Now the connection doesn't take very long, because he keeps losing the connection all the time.
Administrators Netduma Fraser Posted June 22 Administrators Posted June 22 Thanks for that, I'll see if the team can try to force through an upgrade for you today
Administrators Netduma Fraser Posted June 23 Administrators Posted June 23 23 hours ago, jorgelcd said: Thank you. I'll be waiting. They weren't able to access, if your ISP modem/router has WiFi, set it up so that it is in bridge or modem mode, you can also use the DMZ. Copy the WAN IP from the R3 (found in Settings > WAN) and enter it into the DMZ function on the ISP modem/router. Then post back here from a device connected to the R3 when you've done that and we'll attempt to connect again.
jorgelcd Posted June 23 Posted June 23 Good morning. I have a question: even if it loses connection every minute, will the remote connection you told me to run still work? Shouldn't the connection be stable for you to be able to access it? I work in networking and I'm almost certain you won't be able to access it. The router has a problem with the kernel; it's constantly intermittent.
jorgelcd Posted June 23 Posted June 23 "I identified from the logs that the antijitter module causes a kernel panic (BUG: spinlock bad magic) at approximately 62 seconds after boot on kernel 4.14.156, causing the router to reboot in a loop. The connection window is too short (~90 seconds) for a remote upgrade to complete successfully. Please advise on an alternative recovery method."
Administrators Netduma Fraser Posted June 24 Administrators Posted June 24 The connection just needs to be open long enough to upload the firmware file to it, it's not a big file so it should be plenty of time
jorgelcd Posted June 25 Posted June 25 Is there any way we can communicate in real time to carry out this procedure? I think it will be more difficult to do it by posting on the forum.
Administrators Netduma Fraser Posted June 26 Administrators Posted June 26 19 hours ago, jorgelcd said: Is there any way we can communicate in real time to carry out this procedure? I think it will be more difficult to do it by posting on the forum. Not exactly no, the devs will just do it when they have a spare moment, you also don't need to be present for them to connect. As long as you've made yourself accessible how I mentioned they will keep trying.
jorgelcd Posted June 26 Posted June 26 I set up the DMZ on my ISP's router pointing to the Netduma's WAN port and ran the remote access command; could you please try accessing it?
jorgelcd Posted June 28 Posted June 28 Good afternoon. Did you manage to get access?Is there any estimate of when they'll be able to access it?
Administrators Netduma Fraser Posted June 29 Administrators Posted June 29 They weren't able to on Friday and aren't available at the weekend, they'll try again today and will see if there is an alternative if they're unable to.
Administrators Netduma Fraser Posted June 30 Administrators Posted June 30 I've not heard anything back yet, as soon as I know I'll let you know
jorgelcd Posted July 1 Posted July 1 Man, I’ve always dreamed of owning a Netduma. I never imagined that once I finally got one, I’d run into all these issues just from performing a factory reset. I’ve been trying to fix this for nearly a month without success; honestly, I’m on the verge of giving up on the Netduma and switching to another router—like a Ubiquiti EdgeRouter running OpenWrt. I’ve worked in IT for over 20 years and have owned plenty of routers, but I’ve never encountered a problem like this with any of them.
Administrators Netduma Fraser Posted July 2 Administrators Posted July 2 8 hours ago, jorgelcd said: Man, I’ve always dreamed of owning a Netduma. I never imagined that once I finally got one, I’d run into all these issues just from performing a factory reset. I’ve been trying to fix this for nearly a month without success; honestly, I’m on the verge of giving up on the Netduma and switching to another router—like a Ubiquiti EdgeRouter running OpenWrt. I’ve worked in IT for over 20 years and have owned plenty of routers, but I’ve never encountered a problem like this with any of them. The R2 was our first foray into our own hardware and we've learnt a lot since then hence the R3 is a lot more robust. You are also on an Early Access version so there can be issues as you've seen. I will come back to you once I know more.
Administrators Netduma Jack B Posted July 7 Administrators Posted July 7 Hi @jorgelcd Can you send me a DM please and we'll work out a timeslot you're available and i can try and push an update to it. I've tried a few times now and have been unable to access it. jorgelcd 1
