Suliman Posted April 11, 2024 Share Posted April 11, 2024 My Speed test is only showing me half of the speed coming from my Internet Provider, I have Neduma R3 new, Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 11, 2024 Administrators Share Posted April 11, 2024 Are you checking the speed test on the router? If so what does speedtest.net show you? Link to comment Share on other sites More sharing options...
Suliman Posted April 11, 2024 Author Share Posted April 11, 2024 its in both Neduma Speed test and the Speedtest.net Link to comment Share on other sites More sharing options...
swippur Posted April 11, 2024 Share Posted April 11, 2024 Rebooting should fix the problem.. it seems to happen when the router has been online for a few days Suliman 1 Link to comment Share on other sites More sharing options...
Suliman Posted April 11, 2024 Author Share Posted April 11, 2024 I tried that and restarted muliple times, it still shows me I have the half of the speed my provider provides, Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 11, 2024 Administrators Share Posted April 11, 2024 What is the model of the modem/router the R3 is connected to and how have you set that to ensure all traffic flows to the R3? E.g. R3 in its DMZ, modem/bridge mode What speeds do you pay for/expect and what are you receiving? Presumably you're testing via ethernet? Link to comment Share on other sites More sharing options...
Suliman Posted April 11, 2024 Author Share Posted April 11, 2024 I am in Saudi, my internet provider is STC, I made sure DMZ is enabled, because I need open NAT, and there is no traffic limits in my internet router, I pay for 500/150 mbps upload and download, I am connected to LAN of course Link to comment Share on other sites More sharing options...
Suliman Posted April 11, 2024 Author Share Posted April 11, 2024 if you want I can ask you to connect via anydesk to check Link to comment Share on other sites More sharing options...
sufangyu0316 Posted April 11, 2024 Share Posted April 11, 2024 You can try turning off QOS to solve this problem Link to comment Share on other sites More sharing options...
Suliman Posted April 12, 2024 Author Share Posted April 12, 2024 how>? Link to comment Share on other sites More sharing options...
DARKNESS Posted April 12, 2024 Share Posted April 12, 2024 @swippur Screen Recording 2024-04-11 at 9.06.57 PM.mov Link to comment Share on other sites More sharing options...
Suliman Posted April 12, 2024 Author Share Posted April 12, 2024 nothing changed, same thing Link to comment Share on other sites More sharing options...
swippur Posted April 12, 2024 Share Posted April 12, 2024 On 4/12/2024 at 1:57 AM, Suliman said: nothing changed, same thing Expand Try disabling ipv6 Link to comment Share on other sites More sharing options...
Suliman Posted April 12, 2024 Author Share Posted April 12, 2024 On 4/12/2024 at 2:35 AM, swippur said: Try disabling ipv6 Expand I have already disabled it :((( Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 12, 2024 Administrators Share Posted April 12, 2024 On 4/11/2024 at 11:04 PM, Suliman said: I am in Saudi, my internet provider is STC, I made sure DMZ is enabled, because I need open NAT, and there is no traffic limits in my internet router, I pay for 500/150 mbps upload and download, I am connected to LAN of course Expand Is that DMZ on the R3 or DMZ on the provider router? Link to comment Share on other sites More sharing options...
Suliman Posted April 12, 2024 Author Share Posted April 12, 2024 On 4/12/2024 at 2:22 PM, Netduma Fraser said: Is that DMZ on the R3 or DMZ on the provider router? Expand its in my Provider internet Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 12, 2024 Administrators Share Posted April 12, 2024 Okay that's good, it can take a few days or longer for some providers when you introduce a new router to have it provide full speeds. How long have you had the R3 connected? Link to comment Share on other sites More sharing options...
Suliman Posted April 12, 2024 Author Share Posted April 12, 2024 On 4/12/2024 at 4:33 PM, Netduma Fraser said: Okay that's good, it can take a few days or longer for some providers when you introduce a new router to have it provide full speeds. How long have you had the R3 connected? Expand over month or two? I dont know if the issue with my provider, when I am connected directly to the provider internet, its ok and provide full speed, through Netduma I am getting half speed, which is weird, can you please help Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 12, 2024 Administrators Share Posted April 12, 2024 Okay that won't be it then, do you have ALL devices connected to the R3? What firmware version are you on? Link to comment Share on other sites More sharing options...
Suliman Posted April 12, 2024 Author Share Posted April 12, 2024 On 4/12/2024 at 5:36 PM, Netduma Fraser said: Okay that won't be it then, do you have ALL devices connected to the R3? What firmware version are you on? Expand all devices are connected to R3 the version is v4.0.21 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 12, 2024 Administrators Share Posted April 12, 2024 Upgrade to the latest here and then see if you still have the issue please: https://forum.netduma.com/topic/53938-new-r3-firmware-4041/ Link to comment Share on other sites More sharing options...
Suliman Posted April 12, 2024 Author Share Posted April 12, 2024 (edited) On 4/12/2024 at 11:00 PM, Netduma Fraser said: Upgrade to the latest here and then see if you still have the issue please: https://forum.netduma.com/topic/53938-new-r3-firmware-4041/ Expand Edited April 12, 2024 by Suliman Link to comment Share on other sites More sharing options...
Suliman Posted April 12, 2024 Author Share Posted April 12, 2024 On 4/12/2024 at 11:00 PM, Netduma Fraser said: Upgrade to the latest here and then see if you still have the issue please: https://forum.netduma.com/topic/53938-new-r3-firmware-4041/ Expand it worked and I can see my speed on speedtest.net is working fine, however the strange part is the speed test in Netduma is not starting seems like stuck, and also Ping Optimizer is also stuck Link to comment Share on other sites More sharing options...
Suliman Posted April 12, 2024 Author Share Posted April 12, 2024 here is the screenshot Link to comment Share on other sites More sharing options...
Fuzy Posted April 13, 2024 Share Posted April 13, 2024 Hi ! Disable IPv6 LAN/WAN on the R3 and restart it. (IPv6 is not of great interest at the moment and will not have an impact on online gaming). Link to comment Share on other sites More sharing options...
