Luis Gomes Posted March 25, 2024 Posted March 25, 2024 6 hours ago, satinghostrider said: Would WPS Functionality be rectified in this update? It is something that I require for my wireless printer and hope that it will be included. Thanks. @Netduma Fraser Did you guys ever think of creating a form for bug submission? Including a section with ways to reproduce a particular bug, how often it happens…basically a way to pass on more concrete information. carmine19 1
Wons Posted March 25, 2024 Posted March 25, 2024 @Netduma Fraser Thanks for the WIP updates on what's happening behind the scenes. Not a lot of people understand how small the ND Team is. For the time being do you have any general suggestions for issues people face? Just a list of known issues and a potential work-arounds and fixes for those issues? Nothing in specific just something to be documented for anyone who has an issue.
Administrators Netduma Fraser Posted March 25, 2024 Administrators Posted March 25, 2024 11 hours ago, satinghostrider said: Would WPS Functionality be rectified in this update? It is something that I require for my wireless printer and hope that it will be included. Thanks. No not in this one. 5 hours ago, Luis Gomes said: @Netduma Fraser Did you guys ever think of creating a form for bug submission? Including a section with ways to reproduce a particular bug, how often it happens…basically a way to pass on more concrete information. It's a nice idea but people would definitely submit non bug issues, easier to curate on the forum and then pass it on to the team manually, I'll collect what I can and they'll ask for more info if needed. 3 minutes ago, Wons said: @Netduma Fraser Thanks for the WIP updates on what's happening behind the scenes. Not a lot of people understand how small the ND Team is. For the time being do you have any general suggestions for issues people face? Just a list of known issues and a potential work-arounds and fixes for those issues? Nothing in specific just something to be documented for anyone who has an issue. Thanks! There aren't any full proof workarounds we know of at the moment. Disabling IPv6 in LAN/WAN and disabling SmartBOOST entirely can help in some cases. satinghostrider, Luis Gomes and Wons 1 2
MambaMentality Posted March 25, 2024 Posted March 25, 2024 Awesome. Looking forward to the addition of Hybrid VPN and the device wifi communication bug fix. My iDevices not communicating correctly is the biggest/only issue I have. Netduma Fraser 1
Goodwinn20 Posted March 26, 2024 Posted March 26, 2024 What’s the return policy 🤣 cause I’ve had this since launch and had nothing but problems and only main reason I bought this was for the vpn and nothing new out about it
Administrators Netduma Fraser Posted March 26, 2024 Administrators Posted March 26, 2024 5 hours ago, Goodwinn20 said: What’s the return policy 🤣 cause I’ve had this since launch and had nothing but problems and only main reason I bought this was for the vpn and nothing new out about it That'll be in the firmware coming, you can see that here: https://netduma.com/terms
Megatf Posted March 28, 2024 Posted March 28, 2024 On 3/23/2024 at 8:17 AM, Netduma Fraser said: We have a firmware being tested internally currently so shouldn't be much longer now. Here is a rough change log so you can get an idea of what it includes. As you can see it's quite a beefy update, hence why it took longer than the previous ones. Addition of Hybrid VPN Improved SmartBOOST performance Various frontend improvements Fix for memory leak (sometimes manifesting as being unable to access the interface) Potential fix for "frequent disconnects" issue Chromecast and local transfers fixed (this is the WiFi bug where devices can't communicate with each other when they're connected to the same WiFi band e.g. 2.4/2.4GHz) Fix for "No Internet Detected" bug in Setup Wizard IPv6 PPPoE now works with SmartBOOST Ping Optimizer reliability improvements UPnP Improvements Before you ask, no I cannot provide this to you before it's deemed to be stable so please don't ask as you'll get a disappointing answer! When ready we will release it, please don't ask for an ETA! Can we actually permanently disable Steady Ping?
Administrators Netduma Fraser Posted March 28, 2024 Administrators Posted March 28, 2024 2 hours ago, Megatf said: Can we actually permanently disable Steady Ping? You can disable it on the Geo-Filter Map, currently if you reboot it will re-enable but we'll change that.
Megatf Posted March 29, 2024 Posted March 29, 2024 On 3/28/2024 at 5:23 AM, Netduma Fraser said: You can disable it on the Geo-Filter Map, currently if you reboot it will re-enable but we'll change that. Even on this upcoming FW still? I live in Hawaii, when I disable it I just want it off, my ping is high enough
Administrators Netduma Fraser Posted March 29, 2024 Administrators Posted March 29, 2024 48 minutes ago, Megatf said: Even on this upcoming FW still? I live in Hawaii, when I disable it I just want it off, my ping is high enough I think so but might be the next one
