justin peryea Posted April 8, 2024 Author Share Posted April 8, 2024 like in the 50s lol Link to comment Share on other sites More sharing options...
justin peryea Posted April 8, 2024 Author Share Posted April 8, 2024 now it says offline dmz active Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 8, 2024 Administrators Share Posted April 8, 2024 That's impossible, it passes all traffic through to the router. Can you provide a screenshot of where it says offline please? Link to comment Share on other sites More sharing options...
justin peryea Posted April 8, 2024 Author Share Posted April 8, 2024 I'm so confused 😕 r3 wan ip going into dmz mode on verizon than that ip into dmz on the r3 the addresses r different one is 168.1 and the other is 168.77 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 9, 2024 Administrators Share Posted April 9, 2024 14 hours ago, justin peryea said: I'm so confused 😕 r3 wan ip going into dmz mode on verizon than that ip into dmz on the r3 the addresses r different one is 168.1 and the other is 168.77 You only need to do one DMZ, that's probably where it's going a bit weird. The R3 WAN IP into the DMZ on Verizon, that's it Link to comment Share on other sites More sharing options...
justin peryea Posted April 9, 2024 Author Share Posted April 9, 2024 got it will try in a bit Netduma Fraser 1 Link to comment Share on other sites More sharing options...
justin peryea Posted April 9, 2024 Author Share Posted April 9, 2024 I did it and it made my upload slower crazy Link to comment Share on other sites More sharing options...
justin peryea Posted April 11, 2024 Author Share Posted April 11, 2024 ok I'm back to just using the r3 and speeds r pretty good on my phone 500 293 but on pc is 800 /200 is there a pc setting I can try Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 11, 2024 Administrators Share Posted April 11, 2024 You could try something like this https://helpdesk.flexradio.com/hc/en-us/articles/202118518-Optimizing-Ethernet-Adapter-Settings-for-Maximum-Performance Link to comment Share on other sites More sharing options...
justin peryea Posted April 11, 2024 Author Share Posted April 11, 2024 quick question if I open certain ports will that make it go faster if so do u know the ports Link to comment Share on other sites More sharing options...
