justin peryea Posted March 21, 2024 Author Share Posted March 21, 2024 I thought did I lost wifi and couldn't get it back I factory rest and disabled it during the setup Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 21, 2024 Administrators Share Posted March 21, 2024 I can't see it now so should be disabled, any higher speeds? Link to comment Share on other sites More sharing options...
justin peryea Posted March 21, 2024 Author Share Posted March 21, 2024 still slow speeds Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 22, 2024 Administrators Share Posted March 22, 2024 If you disable SmartBOOST fully on the page by clicking the icon what do you get then? Link to comment Share on other sites More sharing options...
justin peryea Posted March 22, 2024 Author Share Posted March 22, 2024 same speeds down its 1 gig for second than goes to between 600 800 upload its around 300 Link to comment Share on other sites More sharing options...
justin peryea Posted March 22, 2024 Author Share Posted March 22, 2024 but the wifi seems to be running better Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 22, 2024 Administrators Share Posted March 22, 2024 I think that'll be the max you can get on this firmware then, the next firmware *might* help but not a guarantee Link to comment Share on other sites More sharing options...
justin peryea Posted March 28, 2024 Author Share Posted March 28, 2024 ok this is weird verizon came out gave me a new ont and router and we got my speeds right with there router I hook my r3 to do a speed test from Verizon and it fails to give me a upload all other speed test still show low upload its weird how just upload is being affected Link to comment Share on other sites More sharing options...
justin peryea Posted March 29, 2024 Author Share Posted March 29, 2024 I hook up Verizon router to r3 and ran Verizon speed test and it works just plug in r3 the test fails at the upload part Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 29, 2024 Administrators Share Posted March 29, 2024 What speed test are you testing the R3 with, the V speed test? What about speedtest.net? Link to comment Share on other sites More sharing options...
justin peryea Posted March 29, 2024 Author Share Posted March 29, 2024 I get the router to get right speeds using Verizon speed test but only if I hook up the r3 to the verizon router if I do a Verizon speed with just the r3 it gets stuck a 50 % than say test failed also if I have both routers hook up and do a speed test on fast.com my download is good but the upload only reaches 100 with out Verizon router I get 300 up sposed to be a gig I don't know if this makes any sense both routers speed is good only on Verizon speed test without the Verizon router test fails but only Verizon speed others work just really slow upload Link to comment Share on other sites More sharing options...
justin peryea Posted March 29, 2024 Author Share Posted March 29, 2024 I have a ont so I shouldn't need to hook up the r3 to there router right? Link to comment Share on other sites More sharing options...
justin peryea Posted March 29, 2024 Author Share Posted March 29, 2024 and would vlan be disabled have anything to do with it Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 29, 2024 Administrators Share Posted March 29, 2024 In theory you shouldn't need to use their router no, if you needed VLAN you wouldn't have internet without it. Even with QoS fully disabled does the upload not move at all? If you use the Verizon router MAC address and set DumaOS to use that instead does that work better when just using ONT and router? Link to comment Share on other sites More sharing options...
Cromkiller1 Posted March 30, 2024 Share Posted March 30, 2024 The same thing has been happening to me with verizon for about 5 years I have gone through 15 routers they replaced the ont 5 times and the router 9, the best thing you can do is replug the ethernet in over and over again until it works. Seriously no joke plug your pc into the ont and I bet you will get the speeds you pay for but it will not go out of most routers. Link to comment Share on other sites More sharing options...
justin peryea Posted March 30, 2024 Author Share Posted March 30, 2024 I changed the mac address same thing verizon speed test fails at the upload download speeds r fine go to a different speed test upload went up on some low on other the ones on the router one went about 300 I don't know if this would make your internet feel faster but my phone runs better Link to comment Share on other sites More sharing options...
justin peryea Posted March 30, 2024 Author Share Posted March 30, 2024 should I try the mac address on my old xr500 I was getting right speeds with that router at one point Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 30, 2024 Administrators Share Posted March 30, 2024 Interesting comments above, I mean there is no reason why the speed suddenly isn't there but yes do try the XR MAC if you received the correct speeds with that Link to comment Share on other sites More sharing options...
KyMa Posted March 30, 2024 Share Posted March 30, 2024 On 3/21/2024 at 12:44 PM, justin peryea said: I pay for a gig both ways it's like the congestion control not working I get the same speeds with speed test bypass off If you are testing bufferbloat you want speedtest bypass off. If you are testing download and upload speeds you want it on. Also, CC doesn’t seem to work with IPV6. So turn it off under WAN AND LAN advanced settings. Link to comment Share on other sites More sharing options...
justin peryea Posted March 30, 2024 Author Share Posted March 30, 2024 same thing upload is slow and fails with Verizon Link to comment Share on other sites More sharing options...
justin peryea Posted March 30, 2024 Author Share Posted March 30, 2024 does ont have a mav address I can try and should i try to put verizon router into bridge mode? Link to comment Share on other sites More sharing options...
justin peryea Posted March 30, 2024 Author Share Posted March 30, 2024 and this is weird when I do speed from Verizon on my phone it's 935 /935 but do it from a different site 90/60 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 30, 2024 Administrators Share Posted March 30, 2024 52 minutes ago, justin peryea said: and this is weird when I do speed from Verizon on my phone it's 935 /935 but do it from a different site 90/60 The Verizon speed test will be going from the modem directly to them so it's probably not even hitting the open internet. Sounds like the cable from the ONT to the modem or R3 might be limited/faulty, if you replace it do you get better speeds from different sites? Link to comment Share on other sites More sharing options...
justin peryea Posted March 30, 2024 Author Share Posted March 30, 2024 same thing slow upload 212 on r3 test 200 other site verizon test fails Link to comment Share on other sites More sharing options...
