Jess Posted March 19, 2023 Posted March 19, 2023 Hello. I just set up my XR1000 for the first time today and am in the process of configuring the various features/settings. While looking at the Deice Manager, I noticed that my PC was showing as offline. I tried reconnecting, running speed tests to see if it triggers the online status, etc. I noticed that even though it shows as offline, when attempting to delete the device, it states that it's unable to because it is online. After experimenting with trying different ports I realized that I was plugged into a 2.5GbE LAN port on my motherboard. I instead switched it to the standard GbE LAN port and the Device Manager immediately detected it as online. Is this a bug or does the XR1000/DumaOS currently not support 2.5GbE?
Krush Posted March 19, 2023 Posted March 19, 2023 Just a graphical bug, I think! By default, network cards are auto-negotiated! You can change the metric of the network card in case another one takes over your PC .... Can also be the EEE function to be turned off on the card! It's definitely something that brings only problems!
crunkjuice1 Posted March 19, 2023 Posted March 19, 2023 I believe all ports on router are standard 1 gig ports.
Administrators Netduma Fraser Posted March 19, 2023 Administrators Posted March 19, 2023 Hey, welcome to the forum! That's very interesting, I don't think we've had anyone report this behavior specifically when using that kind of network adapter. I will make a ticket for this issue, however, the ports on the router are limited to 1Gbps.
Jess Posted March 20, 2023 Author Posted March 20, 2023 Thanks all! I didn't know the ports on the XR1000 are all 1GbE so that makes it a non-issue. 🙂👍 Appreciate the responses!
