yhsuP Posted July 28, 2015 Posted July 28, 2015 What does this setting do exactly and what are the pros of cons of using this feature?
Clinton92 Posted July 28, 2015 Posted July 28, 2015 Wifi workaround is if you were having issues with the wifi dropping out. You would untick in miscellaneous if there were no issues with the wifi just leave it ticked... I could be wrong but I certain that's what its for
lukasz Posted July 28, 2015 Posted July 28, 2015 Thats exsacly what happend to me. I had my wifi droping out. After some time this option was added. Then i was adviced to unticked it to fix wifi droping out and it did. Again this is not a technical explenation of it but like clinton sad you would only need to ether ticked it or untick it if you had a problem with wifi
Zennon Posted July 28, 2015 Posted July 28, 2015 Over all the support posts i see most need it unticked, i hope for it to be unticked by default in the next firmware update.
Netduma Staff Netduma Crossy Posted July 28, 2015 Netduma Staff Posted July 28, 2015 Just to add I believe the actual feature it is to help in congested Wifi areas
