jame0174 Posted August 12, 2022 Posted August 12, 2022 i restarted my r2 and this happened not sure bet every thing is like this
jame0174 Posted August 12, 2022 Author Posted August 12, 2022 i think i bricked the router plus the Ethernet port still falls out .Any way to get it fixed
Netduma Liam Posted August 12, 2022 Posted August 12, 2022 Have you upgraded the R2 recently? If so did you factory reset it afterwards? Could you try accessing the interface from a different browser you don't typically use and see if it loads properly there?
jame0174 Posted August 12, 2022 Author Posted August 12, 2022 It's the same with a different browser.I did the upgrade the day it came out and everything was fine .I Was having problem with it dropping internet so i had to go back to the xr1000.I reset it with a paperclip and this happened is there a way to fix or do i eat the loss
Netduma Liam Posted August 12, 2022 Posted August 12, 2022 1 hour ago, jame0174 said: It's the same with a different browser.I did the upgrade the day it came out and everything was fine .I Was having problem with it dropping internet so i had to go back to the xr1000.I reset it with a paperclip and this happened is there a way to fix or do i eat the loss OK, when you reset it, did you hold the button down for at least thirty seconds? Did you have to complete the setup wizard again? Could you please hit F12 on the DumaOS page, then in the Dev tools click the Network Tab, then tick Disable Cache. Then refresh the page and see if the issue persists?
jame0174 Posted August 12, 2022 Author Posted August 12, 2022 will do but cant till this evening because my wife is working and i can't disrupt the internet thanks for the response
Administrators Netduma Fraser Posted August 14, 2022 Administrators Posted August 14, 2022 On 8/12/2022 at 4:05 PM, jame0174 said: will do but cant till this evening because my wife is working and i can't disrupt the internet thanks for the response Were you able to get this sorted with the above advice?
jame0174 Posted August 17, 2022 Author Posted August 17, 2022 I was wondering if i can use both r2 and xr1000 at the same time.My modem cm1200 has for Ethernet ports i can leave the xr1000 hooked up for my wife and i would use the r2.So that way i dont have to keep unhooking and rehooking the routers up if possable
Administrators Netduma Fraser Posted August 17, 2022 Administrators Posted August 17, 2022 You can't have multiple devices connected to a pure modem directly but you could do CM1200 > R2 > XR1000 (AP mode) and that would work just fine!
jame0174 Posted August 17, 2022 Author Posted August 17, 2022 So i put the xr1000 in ap mode and hooke the r2 to that. Do i use wan or just an open Ethernet port
Administrators Netduma Fraser Posted August 17, 2022 Administrators Posted August 17, 2022 So modem LAN port to R2 internet/WAN port then an R2 LAN port to the XR internet/WAN port and then set the XR to AP mode and you're good to go
jame0174 Posted August 18, 2022 Author Posted August 18, 2022 my only concern is if the r2 loses internet my wife will two.She works from home and i don't have time to leave my job to go and reset everything,
Netduma Liam Posted August 18, 2022 Posted August 18, 2022 8 hours ago, jame0174 said: my only concern is if the r2 loses internet my wife will two.She works from home and i don't have time to leave my job to go and reset everything, That shouldn't happen, although if it's does you can pretty much always get the connection back by just removing the power cord from the R2 for a couple of minutes, then reconnect it.
