kenny Reel Posted June 22, 2022 Posted June 22, 2022 so everytime i click a link someone sends me it will not work itll say DNS_PROBE_FINISHED_NXDOMAIN it randomly started doing this. ice reset my router an modem still order work. i’ve tried deleting my cache an flushing my dns still doesn’t work. idk what happened but it’s very frustrating.
Netduma Liam Posted June 22, 2022 Posted June 22, 2022 1 hour ago, kenny Reel said: so everytime i click a link someone sends me it will not work itll say DNS_PROBE_FINISHED_NXDOMAIN it randomly started doing this. ice reset my router an modem still order work. i’ve tried deleting my cache an flushing my dns still doesn’t work. idk what happened but it’s very frustrating. Does this still occur if you are connected directly to the modem instead of the R2? Have you set your own DNS settings on the R2 or on your PC at all?
kenny Reel Posted June 22, 2022 Author Posted June 22, 2022 10 hours ago, Netduma Liam said: Does this still occur if you are connected directly to the modem instead of the R2? Have you set your own DNS settings on the R2 or on your PC at all? haven’t tried straight to modem an no i haven’t changed settings for dns on r2
Netduma Liam Posted June 23, 2022 Posted June 23, 2022 12 hours ago, kenny Reel said: haven’t tried straight to modem an no i haven’t changed settings for dns on r2 OK, could you please test if it still occurs straight to the modem?
kenny Reel Posted June 24, 2022 Author Posted June 24, 2022 14 hours ago, Netduma Liam said: OK, could you please test if it still occurs straight to the modem? it started happening after i updated to the newest firmware
kenny Reel Posted June 24, 2022 Author Posted June 24, 2022 15 hours ago, Netduma Liam said: OK, could you please test if it still occurs straight to the modem? tried it on my modem an it works just fine its just not working on my router idk why after i did the update is when this started happening it even happens on my phone as well
kenny Reel Posted June 24, 2022 Author Posted June 24, 2022 15 hours ago, Netduma Liam said: OK, could you please test if it still occurs straight to the modem? switched back to my router an its doing this again
Netduma Liam Posted June 24, 2022 Posted June 24, 2022 Can you try completely disabling QoS from the three-line menu in Congestion Control and see if it works then?
kenny Reel Posted June 24, 2022 Author Posted June 24, 2022 54 minutes ago, Netduma Liam said: Can you try completely disabling QoS from the three-line menu in Congestion Control and see if it works then? still didnt work
Netduma Liam Posted June 24, 2022 Posted June 24, 2022 Do you have any Traffic Controller rules currently configured? Are you using Adblocker at all?
kenny Reel Posted June 24, 2022 Author Posted June 24, 2022 3 hours ago, Netduma Liam said: Do you have any Traffic Controller rules currently configured? Are you using Adblocker at all? no traffic rules an adblocker has always been on. i haven’t changed any settings on my router settings. after i updated it’s been doing this.
Administrators Netduma Fraser Posted June 24, 2022 Administrators Posted June 24, 2022 Did you do a proper factory reset after the update? I know you said you reset but do you mean a factory reset or a reboot?
kenny Reel Posted June 24, 2022 Author Posted June 24, 2022 5 hours ago, Netduma Fraser said: Did you do a proper factory reset after the update? I know you said you reset but do you mean a factory reset or a reboot? no i haven’t factory reset it.
Administrators Netduma Fraser Posted June 24, 2022 Administrators Posted June 24, 2022 Hold the reset button for 30 seconds, release, wait 2 minutes then access, go through the wizard then see if it is working. A factory reset is a good idea after an update as it removes any remnants from the previous version that may linger and cause issues.
kenny Reel Posted June 25, 2022 Author Posted June 25, 2022 1 hour ago, Netduma Fraser said: Hold the reset button for 30 seconds, release, wait 2 minutes then access, go through the wizard then see if it is working. A factory reset is a good idea after an update as it removes any remnants from the previous version that may linger and cause issues. did that an still doing the same thing
Administrators Netduma Fraser Posted June 25, 2022 Administrators Posted June 25, 2022 What is the model of the modem/router the R2 is connected to and how is it setup modem/bridge mode or R2 in its DMZ etc?
kenny Reel Posted June 25, 2022 Author Posted June 25, 2022 34 minutes ago, Netduma Fraser said: What is the model of the modem/router the R2 is connected to and how is it setup modem/bridge mode or R2 in its DMZ etc? it’s a arris surfboard sb8200. just have ethernet going from thst to my router an ethernet from router to my pc. never have touched anything in bridge mode or dmz ever
kenny Reel Posted June 25, 2022 Author Posted June 25, 2022 if i go in to change adapter settings on my ethernet settings (not in the netduma interface) like from my desktop if i change the dns to googles i can click on links but when i take it off it stops. which don’t make any sense cause before the update i never had an issue
Administrators Netduma Fraser Posted June 25, 2022 Administrators Posted June 25, 2022 Okay interesting, in Network Settings on the R2, on the WAN side under network, is Use upstream DNS toggled on? If it is toggle it off then toggle on DNS Override and put 1.1.1.1 in primary DNS & 1.0.0.1 in secondary DNS, save network and see if it works then
kenny Reel Posted June 26, 2022 Author Posted June 26, 2022 13 hours ago, Netduma Fraser said: Okay interesting, in Network Settings on the R2, on the WAN side under network, is Use upstream DNS toggled on? If it is toggle it off then toggle on DNS Override and put 1.1.1.1 in primary DNS & 1.0.0.1 in secondary DNS, save network and see if it works then i’ve never done anything tho in adapter settings an added a dns an don’t want a secondary dns
kenny Reel Posted June 26, 2022 Author Posted June 26, 2022 15 hours ago, Netduma Fraser said: Okay interesting, in Network Settings on the R2, on the WAN side under network, is Use upstream DNS toggled on? If it is toggle it off then toggle on DNS Override and put 1.1.1.1 in primary DNS & 1.0.0.1 in secondary DNS, save network and see if it works then that didnt work either
Administrators Netduma Fraser Posted June 26, 2022 Administrators Posted June 26, 2022 A secondary DNS is important because it takes over if the primary DNS fails e.g. if the server goes down, the secondary DNS still uses the same company e.g. Cloudflare or Google, if you're not putting it in and primary goes down that could be related to the issue. Setting on the PC works but doing so on the router doesn't? Could you provide a screenshot of how it is set please?
kenny Reel Posted June 26, 2022 Author Posted June 26, 2022 5 hours ago, Netduma Fraser said: A secondary DNS is important because it takes over if the primary DNS fails e.g. if the server goes down, the secondary DNS still uses the same company e.g. Cloudflare or Google, if you're not putting it in and primary goes down that could be related to the issue. Setting on the PC works but doing so on the router doesn't? Could you provide a screenshot of how it is set please? i set it exactly how you told me to set it. an it didn’t work
Administrators Netduma Fraser Posted June 26, 2022 Administrators Posted June 26, 2022 We've seen a similar issue with someone else so we'll take a look, in the meantime use DNS on the device itself to ensure a stable connection.
kenny Reel Posted June 26, 2022 Author Posted June 26, 2022 2 hours ago, Netduma Fraser said: We've seen a similar issue with someone else so we'll take a look, in the meantime use DNS on the device itself to ensure a stable connection. i have a internet connection just can’t click on clinks. it does it on my phone also but once o turn wifi off my phone an use just data it works fine again.
