Ray96 Posted May 15, 2022 Share Posted May 15, 2022 Link to comment Share on other sites More sharing options...
Ray96 Posted May 15, 2022 Author Share Posted May 15, 2022 Link to comment Share on other sites More sharing options...
titofuenla Posted May 15, 2022 Share Posted May 15, 2022 Hello Ray96! What do you need exactly? what is happening to him? He has only uploaded some photos of the registry, if you do not explain what you need to know, it is difficult to give you a concrete answer. A greeting! Link to comment Share on other sites More sharing options...
Ray96 Posted May 15, 2022 Author Share Posted May 15, 2022 im curious to know what " A default route is present but there is no public prefix on lan thus we don't announce a default route!" i have been using hybrid vpn for a couple weeks now then it started not to work one day and im unsure why that is. it says connected but my location doesnt change anymore like it use to do before it started acting up. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 15, 2022 Administrators Share Posted May 15, 2022 The logs are generally for the developers and not for the users as normal entries can appear as though they are issues. Can you provide a screenshot of your HybridVPN page please? Also you have a modem/router the R2 is connected to, is that in modem/bridge mode or have you put the R2 WAN IP in its DMZ? Link to comment Share on other sites More sharing options...
Ray96 Posted May 15, 2022 Author Share Posted May 15, 2022 I had DMZ activated but I turned it off to see if it would fix my issue it hasn’t. Also not sure if it makes any difference I use Hard wire not wifi Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 15, 2022 Administrators Share Posted May 15, 2022 You haven't enabled the VPN or added a device to the VPN, that's why it isn't working, do that and it will work Link to comment Share on other sites More sharing options...
Ray96 Posted May 15, 2022 Author Share Posted May 15, 2022 I’ve been using the hybrid Von for awhile now. I recently factory reset my netduma once the issued started happening. I know the vpn has to be on an I’ve added my device to the vpn before also. It just doesn’t work anymore. I’ve tried that. Unsure what the problem is Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 15, 2022 Administrators Share Posted May 15, 2022 1 minute ago, Ray96 said: I’ve been using the hybrid Von for awhile now. I recently factory reset my netduma once the issued started happening. I know the vpn has to be on an I’ve added my device to the vpn before also. It just doesn’t work anymore. I’ve tried that. Unsure what the problem is I need a screenshot of how you usually have the VPN setup, you should have the R2 in the DMZ of the ISP router generally Link to comment Share on other sites More sharing options...
Ray96 Posted May 16, 2022 Author Share Posted May 16, 2022 I tried that also Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 16, 2022 Administrators Share Posted May 16, 2022 I need a screenshot of how you usually have the VPN setup Link to comment Share on other sites More sharing options...
Ray96 Posted May 17, 2022 Author Share Posted May 17, 2022 67444108344__335E7493-E1EA-4779-829A-79ED2C2F80D5.MOV Link to comment Share on other sites More sharing options...
Netduma Liam Posted May 17, 2022 Share Posted May 17, 2022 Could you please quickly reboot the R2 then try again, that should clear that error for you. Link to comment Share on other sites More sharing options...
Ray96 Posted May 17, 2022 Author Share Posted May 17, 2022 I restarted it. Says the same thing Link to comment Share on other sites More sharing options...
Ray96 Posted May 17, 2022 Author Share Posted May 17, 2022 None the less I switched it to my IPv4. It connected. But vpn still isn’t working Link to comment Share on other sites More sharing options...
Netduma Liam Posted May 18, 2022 Share Posted May 18, 2022 10 hours ago, Ray96 said: None the less I switched it to my IPv4. It connected. But vpn still isn’t working In what way is it not working exactly? How are you testing it? Link to comment Share on other sites More sharing options...
Ray96 Posted May 18, 2022 Author Share Posted May 18, 2022 It says connected, but it isn’t switching my location. That’s the problem I’m having. Link to comment Share on other sites More sharing options...
Netduma Liam Posted May 19, 2022 Share Posted May 19, 2022 16 hours ago, Ray96 said: It says connected, but it isn’t switching my location. That’s the problem I’m having. Have you added your device in the 'VPN traffic' panel on the right? Link to comment Share on other sites More sharing options...
Ray96 Posted May 19, 2022 Author Share Posted May 19, 2022 Yes I did Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 19, 2022 Administrators Share Posted May 19, 2022 How have you added it exactly, can you provide a screenshot please? Link to comment Share on other sites More sharing options...
Ray96 Posted May 19, 2022 Author Share Posted May 19, 2022 Link to comment Share on other sites More sharing options...
Ray96 Posted May 19, 2022 Author Share Posted May 19, 2022 Goijg through all my settings on both routers it seems the ip etc. is not the same. Seems it’s set as 2 different routers is it suppose to be set as such? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 19, 2022 Administrators Share Posted May 19, 2022 The location aspect of the game may not be using 443, it would be best to apply to the whole device, then the location will change. Could you clarify what you mean exactly? Link to comment Share on other sites More sharing options...
Ray96 Posted May 19, 2022 Author Share Posted May 19, 2022 how exactly do i apply who whole device? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted May 19, 2022 Administrators Share Posted May 19, 2022 Delete the port rule you made then switch it to Do NOT VPN these services Link to comment Share on other sites More sharing options...
