Administrators Netduma Fraser Posted March 3, 2022 Administrators Posted March 3, 2022 That is likely to be the max you can get then unfortunately, we do have some users that can reach ~900Mbps + but it does seem to depend - the rule I had you do basically directs and prioritizes all traffic from the testing device so if that's not getting you any higher there won't be any more settings we can change. It's possible in the next version or one after that, that it could be improved as we will have something that will reduce CPU usage if that is the cause - what does the CPU show on System Information when doing a speedtest?
SocomRaised Posted March 4, 2022 Author Posted March 4, 2022 On 3/2/2022 at 4:22 PM, Netduma Fraser said: That is likely to be the max you can get then unfortunately, we do have some users that can reach ~900Mbps + but it does seem to depend - the rule I had you do basically directs and prioritizes all traffic from the testing device so if that's not getting you any higher there won't be any more settings we can change. It's possible in the next version or one after that, that it could be improved as we will have something that will reduce CPU usage if that is the cause - what does the CPU show on System Information when doing a speedtest? During the speedtest it was around 20%. If this gets resolved in an update please keep me posted.
Netduma Liam Posted March 4, 2022 Posted March 4, 2022 5 hours ago, SocomRaised said: During the speedtest it was around 20%. If this gets resolved in an update please keep me posted. Thanks for letting us know, we will do.
zman1156 Posted March 6, 2022 Posted March 6, 2022 Hopefully you can get your gigabit speeds but to be honest i dont think anyone bought this router for gig speeds. Just saying. Cheers net duma i love u 🥰
