cyberpunk-bg Posted June 4, 2021 Posted June 4, 2021 I can not connect my Mac mini to internet and dumaos I try with cable and wifi the same results . I have MacBook Pro and connect to nedtuma without problem also all my device do not have problem only Mac mini. How to allow Mac mini to have Internet when is connect to netduma
Newfoundland Posted June 4, 2021 Posted June 4, 2021 Hi have you altered the DHCP and IP address. If so you need to be on auto and renew it if you have altered it manually ie looking at stats on a modem for example.
Administrators Netduma Fraser Posted June 4, 2021 Administrators Posted June 4, 2021 Good advice above. Does the Mac connect to the WiFi and get an IP address even without internet or does it fail to connect at all?
cyberpunk-bg Posted June 5, 2021 Author Posted June 5, 2021 Mac connect to the WiFi and in dumaos I see that is connect but do not have internet
Administrators Netduma Fraser Posted June 5, 2021 Administrators Posted June 5, 2021 Check the Device Manager, does the Mac appear as a black icon? Are you using Traffic Controller or Adblocker at all?
cyberpunk-bg Posted June 27, 2021 Author Posted June 27, 2021 No I do not use it traffic controller and Adblocker
Administrators Netduma Fraser Posted June 27, 2021 Administrators Posted June 27, 2021 It doesn't appear as a black icon on the Device Manager either? Also it's worth having a look online as it's specific to one device it indicates something to do with the device rather than the router, here is an example which has some steps you can follow and see if they fix the issue https://appletoolbox.com/solved-macbook-connects-to-wi-fi-but-has-no-internet-connection/
cyberpunk-bg Posted June 27, 2021 Author Posted June 27, 2021 I see in device manager my Mac mini but stil do not have internet ! How I can connect with every other router without problem and have problem only with netduma t? This think do not help me that you post I altered DHCP and IP but stil do not have internet
Exe_uz Posted June 27, 2021 Posted June 27, 2021 Try and delete both the ethernet and wifi options in your system preferences and then re-add and use the automatic settings as mentioned previous, it worked for me 🙂
Administrators Netduma Fraser Posted June 27, 2021 Administrators Posted June 27, 2021 46 minutes ago, cyberpunk-bg said: I see in device manager my Mac mini but stil do not have internet ! How I can connect with every other router without problem and have problem only with netduma t? This think do not help me that you post I altered DHCP and IP but stil do not have internet What colour does the MAC appear as on the Device Manager? You didn't mention it worked with other routers. There was quite a few suggestions on the link, they're worth a try. Would be good if we could see what happens from the above suggestion as well
cyberpunk-bg Posted June 29, 2021 Author Posted June 29, 2021 All icon is red in device manager I read I try but do not work again
Administrators Netduma Fraser Posted June 29, 2021 Administrators Posted June 29, 2021 Try disabling QoS fully from the Congestion Control menu and see whether it works then
