hartspu Posted May 12, 2021 Posted May 12, 2021 Hi, I'm new on netduma r2 and my 2.4GHz wifi speed is too low (0,5mbps). The 5GHz is fine (51mbps.)
Netduma Liam Posted May 12, 2021 Posted May 12, 2021 Welcome to the forum! Do you have the two networks mirrored in Network Settings -> Wi-Fi? Or are they seperated into two different networks? I'd also suggest using a Wi-Fi anaylser to find the least congested channels in your area then adjust your 2.4GHz settings accordingly.
hartspu Posted May 12, 2021 Author Posted May 12, 2021 No I have them separated cause many devices uses the 2.4GHz. Channel 6 is not used by anyone in my area so I choosed this. I have tried all channels but speed is the same.
Newfoundland Posted May 12, 2021 Posted May 12, 2021 Where is the router placed, is it near other electrical equipment? are you using 20 or 40Mhz bandwidth on the 2.4. If 40 I would select 20mhz.
hartspu Posted May 12, 2021 Author Posted May 12, 2021 I tried both but the same. Now I set it to automatic. The only thing I didn't check is the wireless telephone which is near the router. I will try now to turn it off
hartspu Posted May 12, 2021 Author Posted May 12, 2021 I turned it off but the problem is still the same. 0.5mbps
Netduma Liam Posted May 12, 2021 Posted May 12, 2021 1 hour ago, hartspu said: I turned it off but the problem is still the same. 0.5mbps If you reboot the R2 do speeds recover or is it consistently this low?
hartspu Posted May 12, 2021 Author Posted May 12, 2021 With rebooting it, still the same. I did a reset to factory settings and now seems to be OK. Not at the full speed (50) but 30mbps in 2.4 ghz on channel 6. I set it with ppoe to have open nat for cod and dns 1.1.1.1 and secondary 1.0.0.1. Qos is 90% download and upload with auto enable. 5ghz has the full speed (50-51mbps)
Netduma Liam Posted May 12, 2021 Posted May 12, 2021 20 minutes ago, hartspu said: With rebooting it, still the same. I did a reset to factory settings and now seems to be OK. Not at the full speed (50) but 30mbps in 2.4 ghz on channel 6. I set it with ppoe to have open nat for cod and dns 1.1.1.1 and secondary 1.0.0.1. Qos is 90% download and upload with auto enable. 5ghz has the full speed (50-51mbps) OK, that may just be a symptom of the Wi-Fi on the R2 not quite being at it's full potential yet, we are planning on improving this through firmware updates in the future. Let us know if you experience any further issues.
