Netduma R2 randomly losing connection
holyfugazi
52 minutes ago, Netduma Fraser said:
Does the Hotbox have a DMZ/bridge/modem option?
Yes, but bridge mode doesnt seem to work for me when I last try, wifi just goes offline
Bridge mode disables all router functions including WiFi and passes all traffic straight through to the R2 - try with this and see if the disconnects continue
Bridge mode doesn't seem to work for me, I had to reset my modem and put it on DMZ(it was on Dmz beforehand) and the connection losses are still happening
I got this error while in bridge mode by the way maybe you could figure out what went wrong.
PS what settings should I turn off in the modem?1778011940_2021-05-0122_42_25-Dashboard-DumaOS.png.d78db5c86dfd89902577d9c1ba7228a4.png1285349504_2021-05-0123_20_23-HOTBOX4.png.5f065a0402ec6c1c842fbf7bb5a6fded.png
That error will be due to an Adblocker on your web browser, if you disable that you shouldn't get it again. Untick WAN Blocking, you can leave everything else, hopefully that could help
I unticked WAN blocking and that did not seem to solve my loss of connection
14 minutes ago, Netduma Fraser said:
When did it first start to occur? After an update, settings change, reboot etc?
It might have started when I had power outages but I can't tell you for sure, I didn't pay attention to it at first then it got reoccuring and more annoying, it only happens with my Netduma router, my downstairs router never loses connection
We are looking at issues with this and will hopefully be fixed in the next version. We could sort out a replacement but there is no guarantee you won't have the issue on that as well
I've had this exact same problem for the last month (since the day I got my router). It randomly looses connection from all devices and reconnections whenever it wants. Can someone please come up with a fix?? I unplugged the router and plugged my old one in for a few days and had ZERO issues.
Do you have an estimate for the next update's date? I could wait if it's not that long otherwise we should be sorting out a replacement
I've responded to you in the post you made :)
I don't have an ETA as yet unforunately, as Fraser mentions we'd be happy to sort a replacement for you but unfortunately there's no guarantee that this will be the solution.
