Ghost-Inside Posted April 1, 2021 Posted April 1, 2021 I need sum help getting my R2set up i have a modem from my internet provider in bridge mode with my main ethernet cable ran from the R2 into my isp modem. I am getting no inter net at alll. I go to where it says Netduma R2 for my network & inter in the password. It keeps telling me there is no internet avaiable for the Netduma R2.I called my isp everything on their end is good is there sumthing im doing wrong? Any help would be greatly apprectited..
Netduma Liam Posted April 1, 2021 Posted April 1, 2021 Does the Wi-Fi password appear to be accepted? If not, it may be that the sticker on the underside of the router is incorrect. Are you able to connect to the R2 via a wired connection? If so, can you go to 192.168.77.1 in your web browser and access the interface?
Ghost-Inside Posted April 1, 2021 Author Posted April 1, 2021 Ok ill start over from fresh. So after i hook everything up an get it going. Do i need to try access the interface to try to gain internet acess b4 i try to get it connected through my phone? Also what if the PASSWORD stiker is wrong how do i get another password code.
Administrators Netduma Fraser Posted April 1, 2021 Administrators Posted April 1, 2021 Yes you will need to access the interface and complete the setup wizard before you get internet. During the wizard you will be given the opportunity to change the WiFi details, you can then use them from then on. You can convert the incorrect password to the correct password using this guide: http://support.netduma.com/en/support/solutions/articles/16000117883-i-ve-received-the-r2-but-the-wifi-password-doesn-t-work
Ghost-Inside Posted April 1, 2021 Author Posted April 1, 2021 Thank you guys so much for the help im realy new to the netduma family & the device. Ill message bck if i still hve problems..
Ghost-Inside Posted April 2, 2021 Author Posted April 2, 2021 Ihave another question should i update my R2.Cause i saw a video that there was an update cause im running on the firmware of the R2 right out of the box. Cause i have a option tht i should have tht im not seeing. Like when i run auto set up to try to find my best connection im not seeing the option sumthing about the PING or BANDWIDTH. If tht makes any sence lol
Administrators Netduma Fraser Posted April 2, 2021 Administrators Posted April 2, 2021 What firmware version are you on currently? You can tell by looking at the top right of the interface or on the System Information page
Ghost-Inside Posted April 2, 2021 Author Posted April 2, 2021 1 hour ago, Netduma Fraser said: What firmware version are you on currently? You can tell by looking at the top right of the interface or on the System Information page I will check when i get home from work. Then ill post the version i am on!!
Ghost-Inside Posted April 3, 2021 Author Posted April 3, 2021 Ok im running on firmware version : 3.0.205 Do i need to update firmware
Administrators Netduma Fraser Posted April 3, 2021 Administrators Posted April 3, 2021 You're on the very latest version so no need to update
Ghost-Inside Posted April 3, 2021 Author Posted April 3, 2021 Ok another question why am i scoreing a "D" every time i run a test. The rest is fine but tht. Also why is it taking 30mins to find a game in Coldwar Pc. And how do i get an open nat on coldwar
Administrators Netduma Fraser Posted April 3, 2021 Administrators Posted April 3, 2021 The speed is under what you have said you get. We're still improving the speeds reported, you can ignore it. Where are you located and where are you trying to force a game? What is the model of the modem/router the R2 is connected to?
Ghost-Inside Posted April 3, 2021 Author Posted April 3, 2021 1 hour ago, Netduma Fraser said: The speed is under what you have said you get. We're still improving the speeds reported, you can ignore it. Where are you located and where are you trying to force a game? What is the model of the modem/router the R2 is connected to? Ok Sounds Good Ty.. I think once i figured out how to get an open Nat Type on Coldwar it may hve fixed the issue with waiting so long. One last question how are these guys finding these 9ms servers on Coldwar all i can find is like 29to35 servers, im in the US, live in Tennessee.. And thnk u guys so much for all the help greatly apprectited..
Administrators Netduma Fraser Posted April 3, 2021 Administrators Posted April 3, 2021 Use Ping Heatmap to identify the lowest ping servers for you, then adjust the Geo-Filter to try and cover those areas, then search. Depending on your ISP, the closest servers etc it may not be possible to get a ping that low.
Ghost-Inside Posted April 3, 2021 Author Posted April 3, 2021 32 minutes ago, Netduma Fraser said: Use Ping Heatmap to identify the lowest ping servers for you, then adjust the Geo-Filter to try and cover those areas, then search. Depending on your ISP, the closest servers etc it may not be possible to get a ping that low. Ok Fair Enough!! Will try that and see what happens. Thnks for ur help Fraser
