gennaro.mercante Posted March 23, 2021 Posted March 23, 2021 howdy, so i recently got my R2 in the mail and when I initially went through the setup wizard I skipped the internet set up and that caused a slue of issues. I was unable to connect my mobiles to wifi, couldnt set up manually on wired connection, etc. ultimately I factory reset and managed to get to the point where I was able to connect my Mac and iPhone to the WiFi (eureka) but when I tried to access Dumaos it said that my account info was incorrect. I tried the factory password, personal password and username I set up previously and no dice. I got frustrated and factory reset the router AGAIN and now I cant even connect mobile devices to the router for initial set up. where am I going wrong here? not super savvy with all this so I am pretty lost unfortunately. any assistance would be helpful! Thanks in advance
Administrators Netduma Fraser Posted March 23, 2021 Administrators Posted March 23, 2021 Hey, welcome to the forum! Sorry to hear you're having this issue. Follow the password conversion method here: http://support.netduma.com/en/support/solutions/articles/16000117883-i-ve-received-the-r2-but-the-wifi-password-doesn-t-work to see if you can get the devices connected to WiFi so you can complete the wizard
gennaro.mercante Posted March 23, 2021 Author Posted March 23, 2021 Thanks for the assistance so far, Fraser! I was able to connect via Wi-Fi and enter the dumaos portal to get things mostly set up, but now it says that my WAN IP is Disconnected. I’m on Google fiber so I went through the Quick setup guide and connected the CAT6 cable directly to the Fiber Jack in the wall. Should I be doing something differently here? I’m going to include more screenshots of what I am seeing on my screen for you if that helps.
Administrators Netduma Fraser Posted March 24, 2021 Administrators Posted March 24, 2021 We usually recommend connecting it to your existing modem/router, in this case the Google hub, then see if you are able to get a connection.
gennaro.mercante Posted March 24, 2021 Author Posted March 24, 2021 Okay so I have the Google Fiber Jack built into the wall, and I have a separate Google Fiber Box that typically acts as the router. Where am I plugging each specific Ethernet cable in?
gennaro.mercante Posted March 24, 2021 Author Posted March 24, 2021 It also says that I’ve transmitted over 21000 bytes, where it was stuck at 100 before. Does that mean anything?
Netduma Liam Posted March 24, 2021 Posted March 24, 2021 Yes that's correct, so you'll have: Wall Jack -> Google Router -> R2 Then reboot the R2 and see if it gets a WAN IP. Where are you seeing that it's saying 21000 bytes transmitted?
gennaro.mercante Posted March 24, 2021 Author Posted March 24, 2021 In the first image I sent under Network Status. Still no WAN IP as of now
Newfoundland Posted March 24, 2021 Posted March 24, 2021 That’s probably just the WiFi looking for stuff. It’s normal so nothing to worry about as I’ve seen this with mine that not connected up online. The count will slowly increase.
gennaro.mercante Posted March 24, 2021 Author Posted March 24, 2021 UPDATE: So i factory reset the router since initial reboot didn’t work, went through setup wizard and it appears that I have a stable internet connection now. WAN IP is now available and once I go through everything else in speed tests I shouldn’t have any more issues. Thanks for all the help! Just was able to hop on the internet for a bit after the recommended changes in hardware setup. But when i pulled up dumaos/ it gave me an initial error and stated in the diagnostic check that, “the network gateway is accessible, but Windows could not receive network traffic from the Internet”. Does that mean I just need to update the information about my ISP router to setup new DNS?
Administrators Netduma Fraser Posted March 24, 2021 Administrators Posted March 24, 2021 Great to hear that! No I don't believe so, if you access using 192.168.77.1 in the browser instead does that give you access? Also to double check were you connected to the R2 when you attempted access?
gennaro.mercante Posted March 24, 2021 Author Posted March 24, 2021 So the issues I was having before were mainly because I didn’t auto connect to WAN via my hardware. I just rebooted the R2 and completely disconnected everything. Using the Quick Setup guide in the user Manuel step by step I ended up having my CAT6 cable provided by Netduma connect from Fiber Jack in wall to WAN Port on Google Fiber Box. Then connected my other Ethernet cable from LAN port on Google Fiber to the WAN port on the R2, with all of my external wired devices connect to the R2 LAN ports. Went through setup guide again and everything auto-populated. Experiencing the same network speeds (1GB Up/Down) with similar ping after testing the geofilter. No issues as of now! Not sure what to do if it doesn’t auto connect but I’m just going to write down everything in system/network info while it’s working so I can replicate it if I need to do it manually. Thanks for all of the assistance! Edit: I can acces both through IP url and dumaos/ url on both wired and WiFi connections to all devices
Administrators Netduma Fraser Posted March 24, 2021 Administrators Posted March 24, 2021 Great to hear that, thanks for the update! Should it not auto connect a reboot should be sufficient
