zaria Posted March 7, 2021 Share Posted March 7, 2021 Hi I am trying to replace my HH3000 with the Netduma R2 using the video bellow. I have bought two different SFP Media converters and have the correct user name an password for PPOE. I am receiving some PPOE errors. EDIT: I did a little research and found that I have to set VLAN to 35, is that something I can do with this router? Do I need to complete the step in this individuals to setup IPTV to VID 35 to get a PPOE connection? Right now in the logs I don't even see any PPOE handshake. In the DumaOS I see data sent but nothing received for WAN. ue Oct 27 10:34:16 2020 daemon.err pppd[7140]: Unable to complete PPPoE Discovery Tue Oct 27 10:34:16 2020 daemon.info pppd[7140]: Exit. Tue Oct 27 10:34:16 2020 daemon.notice netifd: Interface 'wan' is now down Tue Oct 27 10:34:16 2020 daemon.notice netifd: Interface 'wan' is disabled Tue Oct 27 10:34:16 2020 daemon.notice netifd: Interface 'wan' is enabled Tue Oct 27 10:34:16 2020 daemon.notice netifd: Interface 'wan' is setting up now Tue Oct 27 10:34:16 2020 daemon.err insmod: module is already loaded - slhc Tue Oct 27 10:34:16 2020 daemon.err insmod: module is already loaded - ppp_generic Tue Oct 27 10:34:16 2020 daemon.err insmod: module is already loaded - pppox Tue Oct 27 10:34:16 2020 daemon.err insmod: module is already loaded - pppoe Tue Oct 27 10:34:16 2020 daemon.info pppd[8145]: Plugin rp-pppoe.so loaded. Tue Oct 27 10:34:16 2020 daemon.info pppd[8145]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 8, 2021 Administrators Share Posted March 8, 2021 Hey, welcome to the forum! VLAN is not currently implemented but will be for the next version I believe. You don't need to replace the hub you can use them together - in fact that is what we usually suggest, to connect it to your existing modem/router to get an internet connection. In your case you will have to do this as VLAN isn't possible at the moment. Link to comment Share on other sites More sharing options...
zaria Posted March 8, 2021 Author Share Posted March 8, 2021 Thanks for the quick reply. Can you direct me to some details of how this can be accomplished? Link to comment Share on other sites More sharing options...
Netduma Liam Posted March 8, 2021 Share Posted March 8, 2021 The setup guide included in the box with the R2 should help you do this Link to comment Share on other sites More sharing options...
zaria Posted March 9, 2021 Author Share Posted March 9, 2021 if the IP for the WAN is obtained by the Bell Modem what do I enter in the WAN setup on the Netduma R2, DHCP or static ? Do I need to enter the WAN ip address in the WAN settings of the router? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 9, 2021 Administrators Share Posted March 9, 2021 29 minutes ago, zaria said: if the IP for the WAN is obtained by the Bell Modem what do I enter in the WAN setup on the Netduma R2, DHCP or static ? Do I need to enter the WAN ip address in the WAN settings of the router? No you just leave that as the default which is DHCP so nothing to change there Link to comment Share on other sites More sharing options...
zaria Posted March 10, 2021 Author Share Posted March 10, 2021 On the same modem ethernet cable I get 1.5 GB download and 1 GB upload. When I connect through Netduma R2 WAN I get 91 mbps up and 91 mbps up. I have tried disabling QOS and all kinds of troubleshooting. I have set router R2 on DMZ Advanced. What do you recommend I try? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 10, 2021 Administrators Share Posted March 10, 2021 Please take a screenshot of the Device Manager table view please and post it here Link to comment Share on other sites More sharing options...
zaria Posted March 10, 2021 Author Share Posted March 10, 2021 Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 10, 2021 Administrators Share Posted March 10, 2021 Thanks, click the 3 horizontal line icon in the top let of the panel, select table view and provide a screenshot please. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 10, 2021 Administrators Share Posted March 10, 2021 You only have two devices connected to the router, where are the other devices connected to? They can take bandwidth away from the router Link to comment Share on other sites More sharing options...
zaria Posted March 10, 2021 Author Share Posted March 10, 2021 I took all devices off to isolate issue, only have a desktop on LAN and laptop on wifi. I connect desktop to LAN modem I get 900 mbps. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted March 10, 2021 Administrators Share Posted March 10, 2021 Are any other devices connected to the modem? Can you connect ALL devices to the R2/disconnect them from the modem and see if it gets higher speeds? It might be that it will take a few days for the ISP to sync with the router as there doesn't appear to be anything else affecting it Link to comment Share on other sites More sharing options...
