help with dumaos
Wilfred Correa
That's normal as it is a local site so no need to worry about that. What do you mean they don't recognize it exactly? Does it get an internet connection?
Did you go through the R2 setup wizard? Or did you complete the setup wizard?
Thanks!
Zippy.
Are you able to connect a computer or laptop wired to one of the LAN ports of the R2? Im pretty sure we need to get you to complete the setup wizard before you can connect.. I think currently one needs to be wired in order to go through the R2 setup wizard.. Once you get to that point you can set your password..
Sometimes one has to factory reset the router from the back.. Hold down the little pin in the back for 30 secs and then release.. Let the R2 fully boot up and proceed through the setup wizard of the R2.. You have to be wired to do this though..  Either access the R2 by dumaos/ or by 192.168.77.1
See if you can get anywhere with that info above.
Good luck!
Zippy.
