How do I connect to specific servers after saving them from the Heat Map?
Dyson350
Saved several low ping servers off the Heat Map. How do I target them to try and only to connect to them? Right now Geo Filter seems to just pick at random.
Thanks for posting!
Geo-filter will pick based on what's offering the best connection, is there a reason why you'd like to connect to these chosen servers specifically?
2 hours ago, Netduma Liam said:
Thanks for posting!
Best ping to server
Saving servers from the heatmap just adds them to a custom list that you can ping on Heatmap. Identify the areas where they are located, then on the Geo-Filter draw polygons around those areas.
