Piece_Of_Paper Posted December 5, 2020 Posted December 5, 2020 I tried to port forward for Minecraft using 25565 but it seems when I apply it and check if its open with a port forwarding checker it always it is closed.
Administrators Netduma Fraser Posted December 5, 2020 Administrators Posted December 5, 2020 Hey, welcome to the forum! What is your exact physical setup? I.e. what is the XR connected to, a pure modem (no wifi) or modem/router (WiFi)
Piece_Of_Paper Posted December 5, 2020 Author Posted December 5, 2020 I have a modem which is connected to my XR500
Piece_Of_Paper Posted December 5, 2020 Author Posted December 5, 2020 38 minutes ago, Netduma Fraser said: Hey, welcome to the forum! What is your exact physical setup? I.e. what is the XR connected to, a pure modem (no wifi) or modem/router (WiFi) I have a modem which is connected to my XR500 (idk how the ping system works thus I did it twice)
Administrators Netduma Fraser Posted December 5, 2020 Administrators Posted December 5, 2020 So a pure modem then? Most of those checkers don't work well, does it actually work for the game? That port needs to be TCP and UDP, you also need 19132-19133 UDP.
Piece_Of_Paper Posted December 5, 2020 Author Posted December 5, 2020 4 minutes ago, Netduma Fraser said: So a pure modem then? Most of those checkers don't work well, does it actually work for the game? That port needs to be TCP and UDP, you also need 19132-19133 UDP. Yes port 25565 is both UDP and TCP and I have also added 19132-19133 UDP and tested once again and it still does not work. I haven't tested it for the game yet as I don't have anyone who can join from somewhere else right now.
Administrators Netduma Fraser Posted December 5, 2020 Administrators Posted December 5, 2020 Port sites are likely using a different source port than the one you've forwarded and will show closed, best way to check is using the game itself.
Piece_Of_Paper Posted December 5, 2020 Author Posted December 5, 2020 5 minutes ago, Netduma Fraser said: Port sites are likely using a different source port than the one you've forwarded and will show closed, best way to check is using the game itself. Alright I will try with the game as soon as possible and tell you if it works or not.
Piece_Of_Paper Posted December 5, 2020 Author Posted December 5, 2020 I just checked and it works! Thank you so much!
Administrators Netduma Fraser Posted December 5, 2020 Administrators Posted December 5, 2020 Great to hear that, thanks for the update! I'll close this topic now as it's been resolved, if you have any more questions/issues feel free to make a new topic.
