rayan Posted October 11, 2020 Posted October 11, 2020 Hi Netduma team I came across an issue with my connection lag spikes all over the place when I gaming and sometimes I can't move in the game (MW) till something happen like someone kills me , round fished or the game ends this is my PingPlotter tests is there a way to fix it it looks not stable . Thanks in advance .
Administrators Netduma Fraser Posted October 11, 2020 Administrators Posted October 11, 2020 Change the interval back to 2.5 please and redo the test as 1 can report false positives.
Administrators Netduma Fraser Posted October 11, 2020 Administrators Posted October 11, 2020 Great thank you for doing that, can you try directly connected to the modem as well please? Also was it done with nothing else using the internet?
Warrior Posted October 11, 2020 Posted October 11, 2020 i seen this before when i did a friends connection it looks like your internet provider is throttling your connection are you using any dns servers ??
Administrators Netduma Alex Posted October 12, 2020 Administrators Posted October 12, 2020 Could you try using a server that you know is relatively nearby, such as a local news site?
rayan Posted October 12, 2020 Author Posted October 12, 2020 Thanks guys for your replies I'm going to test it again when I'm home .
rayan Posted October 12, 2020 Author Posted October 12, 2020 I've done the test again using two different ips from Amazon servers in Bahrain nearby me and that's what I got but the issue still there as I mentioned before packet loose and sometimes I couldn't move till something happen . Thanks in advance
Warrior Posted October 13, 2020 Posted October 13, 2020 wat modem router are you using and are you using qos?
rayan Posted October 13, 2020 Author Posted October 13, 2020 Modem : Zhone fiber Router : Netduma R1 Firmware : Beta R1 3.0.105
Administrators Netduma Fraser Posted October 13, 2020 Administrators Posted October 13, 2020 It looks like it was just a server issue and nothing on your side!
Warrior Posted October 14, 2020 Posted October 14, 2020 yeah by the graphs in ping plotter looks like a isp problem they might be throttling your connection make sure always to have the highest plan cause thats the last plan they throttle
