Squidid Posted October 1, 2020 Posted October 1, 2020 I contacted the century link (my ISP) and helped me with some settings to setup the bridging mode but, there's no internet connection so they told me to contact you guys and they gave me info about PPP.
Squidid Posted October 1, 2020 Author Posted October 1, 2020 2 minutes ago, BoiDjakoCV said: Hi login PPP Here Should I enable MTU or any of those other settings?
Squidid Posted October 1, 2020 Author Posted October 1, 2020 1 minute ago, BoiDjakoCV said: no just username and pass .. Okay. So I did just that and I still dont have internet but, now I can't access the ISP router. Also in the bridging mode in the ISP router there's tagged 201, untagged, custom and other stuff. It's set to tagged 201.
BoiDjakoCV Posted October 1, 2020 Posted October 1, 2020 My Advise contacted Netduma Fraser R2 ip 192.168.77.1 ...
BoiDjakoCV Posted October 1, 2020 Posted October 1, 2020 how did you connect ethernet cable from modem to R2 ?
Squidid Posted October 1, 2020 Author Posted October 1, 2020 11 minutes ago, BoiDjakoCV said: My Advise contacted Netduma Fraser R2 ip 192.168.77.1 ... I just did. 3 minutes ago, BoiDjakoCV said: how did you connect ethernet cable from modem to R2 ? Thru a cat7 cable. Port 1.
Squidid Posted October 1, 2020 Author Posted October 1, 2020 Just now, BoiDjakoCV said: do have 4 yellow ports on you modem ? No, just 3. That is the power, WAN/LAN, and ethernet 1.
BoiDjakoCV Posted October 1, 2020 Posted October 1, 2020 ok connect cat 7 to ethernet 1on modem to port 1on R2
Squidid Posted October 1, 2020 Author Posted October 1, 2020 1 minute ago, BoiDjakoCV said: ok connect cat 7 to ethernet 1on modem to port 1on R2 It's already setup like that.
BoiDjakoCV Posted October 1, 2020 Posted October 1, 2020 Contacted Frazer or u will get frustrated 👊🏽
Squidid Posted October 1, 2020 Author Posted October 1, 2020 2 minutes ago, BoiDjakoCV said: Contacted Frazer or u will get frustrated 👊🏽 Already did. Just waiting for him to reply.
Administrators Netduma Jack B Posted October 1, 2020 Administrators Posted October 1, 2020 Hi @Squidid You should be connecting from a LAN port on the modem to the blue WAN port on the R2. If you have plugged it in correctly , in the System Information tab you should be able to see a WAN IP listed in the Network Status box. If the WAN IP is being displayed you should be able to access your modem and the internet.
Squidid Posted October 1, 2020 Author Posted October 1, 2020 10 minutes ago, Netduma Jack B said: Hi @Squidid You should be connecting from a LAN port on the modem to the blue WAN port on the R2. If you have plugged it in correctly , in the System Information tab you should be able to see a WAN IP listed in the Network Status box. If the WAN IP is being displayed you should be able to access your modem and the internet. Lan port from the modem not the ethernet port? Or is that the same? Here are some pictures. 2nd pic is the ISP modem.
Guest Killhippie Posted October 1, 2020 Posted October 1, 2020 Have you tried putting your username and password into the R2 during the setup wizard? It wont connect without that using PPPoE. What make is your Modem router?
Squidid Posted October 1, 2020 Author Posted October 1, 2020 2 minutes ago, Killhippie said: Have you tried putting your username and password into the R2 during the setup wizard? It wont connect without that using PPPoE. What make is your Modem router? What setup wizard? Do you mean to reset to the R2? The modem router is Centurylink C3000Z.
Guest Killhippie Posted October 1, 2020 Posted October 1, 2020 3 minutes ago, Squidid said: What setup wizard? Do you mean to reset to the R2? The modem router is Centurylink C3000Z. when you turn the R2 on for the first time a setup routine appears, you need to put your credentials for your ISP into the R2 as in bridge mode I'm not sure the modem will do that. Have you gone though the setup routine as I mentioned, or seen one? Is the R2 connected to a PC?
Squidid Posted October 1, 2020 Author Posted October 1, 2020 1 minute ago, Killhippie said: when you turn the R2 on for the first time a setup routine appears, you need to put your credentials for your ISP into the R2 as in bridge mode I'm not sure the modem will do that. Have you gone though the setup routine as I mentioned, or seen one? I will do that now. Hold on.
BoiDjakoCV Posted October 1, 2020 Posted October 1, 2020 How to step up bridge mode https://medium.com/@acnc111/setting-a-centurylink-c3000z-modem-router-to-bridge-mode-and-using-a-linksys-router-63e9e1329201
Squidid Posted October 1, 2020 Author Posted October 1, 2020 6 minutes ago, Killhippie said: when you turn the R2 on for the first time a setup routine appears, you need to put your credentials for your ISP into the R2 as in bridge mode I'm not sure the modem will do that. Have you gone though the setup routine as I mentioned, or seen one? Is the R2 connected to a PC? So I just did the setup and after typing in the credentials and submitting, it's saying "Could not detect an Internet Connection". Yes the R2 is connected to a PC.
Squidid Posted October 1, 2020 Author Posted October 1, 2020 5 minutes ago, BoiDjakoCV said: How to step up bridge mode https://medium.com/@acnc111/setting-a-centurylink-c3000z-modem-router-to-bridge-mode-and-using-a-linksys-router-63e9e1329201 I cannot access the modem anymore after the bridging mode.
Guest Killhippie Posted October 1, 2020 Posted October 1, 2020 1 minute ago, Squidid said: I cannot access the modem anymore after the bridging mode. You would need to connect to the Century link to the PC log in and take it out of bridge mode. Do you know if you are PPPoE or DHCP? It would be useful to copy the settings from the century link. first so you know your username and, password and connection type. Maybe @Zippy can help with this one as he is from the states.
titofuenla Posted October 1, 2020 Posted October 1, 2020 I advise you before you go crazy, to check with your Isp if you use Vlan in addition to Pppoe, some providers and more, if they are fiber, use Vlan to label their traffic on the network.
