GEO FILTER PROBLEM!
There has to be something blocked then, be fully zoomed out and be looking at the map at the same time as it will be very quick when it appears then you need to allow it.
  • 4 weeks later...
  • Replies 92
Hi, I'm getting back to you because there are always problems playing destiny with the active filter!  If I authorize my friends I can play in the game with them, but if I want to play normal pvp games I can't because it knocks me out of the game!  There are still serious problems
Yes we are still investigating, we will tell people once we have a solution, for now use Spectating Mode.
@Fede_b34st tanto il 10 novembre cambieranno i server in destiny 2, quindi non sarà più tanto utile e dato che la data e vicina io ormai mi sono arreso a trovare una soluzione.
Hi al!
Im affected  too for the geofilter Issues in destiny 2 on PC. I was wondering if Upgrading firmware to duma 3.0 would solve these problems (geofilter and black/white connections. I bought the x500 basically to use these features in pvp matches.
Thx for advance!
I don't think you'll be able to fix anything by installing the new version
@Fede_b34stio sto bestemmiando pazientemente.
Se passa un altro po' divento io un tecnico informatico della netgear per tutte le prove che ho fatto.
We have not yet resolved the Destiny problem, we will post when we have any more information on it. For now disabling Filtering Mode.
39 minutes ago, Fede_b34st said:
Do you think you can solve it by the release of Playstation 5?
Unlikely, it is due to their server changes, nothing to do with the game platform.
56 minutes ago, Fede_b34st said:
So will it take months to fix that problem?
It will take a while yes as changes to the Geo-Filter itself will need to be made to try and counteract their changes.
