Axel Posted September 24, 2020 Posted September 24, 2020 the screen I sent and while I am in matchmaking before I am thrown out, instead on r6 nothing comes out on the geofilters the same on gta but while doing the search for an activity, instead if I want to find a session the player icon comes out normally
Administrators Netduma Fraser Posted September 25, 2020 Administrators Posted September 25, 2020 Try the beta firmware and see if it works any better for you https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
Administrators Netduma Fraser Posted September 25, 2020 Administrators Posted September 25, 2020 It's under the topic Latest Firmware Download when you go on that link.
Fede_b34st Posted September 25, 2020 Author Posted September 25, 2020 Later I will try and will report to you
Axel Posted September 25, 2020 Posted September 25, 2020 @Netduma Fraser when i go your link i get this
Axel Posted September 25, 2020 Posted September 25, 2020 i keep this version already istalled, i may access to version 3.0 please ?
Administrators Netduma Fraser Posted September 25, 2020 Administrators Posted September 25, 2020 16 minutes ago, Axel said: @Netduma Fraser when i go your link i get this You need to be logged into the Netgear community and then you will be able to access it.
Axel Posted September 25, 2020 Posted September 25, 2020 yes, i logged in but it gives me as the latest version the one already istalled. Could i have version 3.0 ?
Administrators Netduma Fraser Posted September 25, 2020 Administrators Posted September 25, 2020 https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/Latest-firmware-download/td-p/1976833/jump-to/first-unread-message
Fede_b34st Posted September 25, 2020 Author Posted September 25, 2020 I managed to download the beta firmwares and it works great! You managed to solve the problem !! Compliments. I also noticed that you have improved the graphics too! Nice work 👏👏
mirkoG Posted September 25, 2020 Posted September 25, 2020 14 minutes ago, Fede_b34st said: THANKS 😁❤️ Come avete risolto col geofilter? Potete spiegarmelo? Grazie
Fede_b34st Posted September 25, 2020 Author Posted September 25, 2020 Basta accedere nel link di sopra 👆 per scaricare il nuovo firmware, dopo averlo scaricato lo carichi nel router, attendi che ritorna la connessione ed hai risolto!
mirkoG Posted September 25, 2020 Posted September 25, 2020 Just now, Fede_b34st said: Basta accedere nel link di sopra 👆 per scaricare il nuovo firmware, dopo averlo scaricato lo carichi nel router, attendi che ritorna la connessione ed hai risolto! Ah ok, io cmq ho il netduma r1. È uguale o è solo per il nighthawk?
Administrators Netduma Fraser Posted September 25, 2020 Administrators Posted September 25, 2020 2 minutes ago, mirkoG said: Ah ok, io cmq ho il netduma r1. È uguale o è solo per il nighthawk? Ti ho dato l'accesso alla beta R1: I have given you access to the R1 beta: https://forum.netduma.com/forum/130-dumaos-30-beta-netduma-r1/
mirkoG Posted September 25, 2020 Posted September 25, 2020 5 minutes ago, Netduma Fraser said: Ti ho dato l'accesso alla beta R1: I have given you access to the R1 beta: https://forum.netduma.com/forum/130-dumaos-30-beta-netduma-r1/ Thank you
mirkoG Posted September 25, 2020 Posted September 25, 2020 1 hour ago, Fede_b34st said: Basta accedere nel link di sopra 👆 per scaricare il nuovo firmware, dopo averlo scaricato lo carichi nel router, attendi che ritorna la connessione ed hai risolto! a meno che io non metta modalità spettatore, gli altri non riescono ad entrare nella mia squadra. lo fa anche a te?
Fede_b34st Posted September 25, 2020 Author Posted September 25, 2020 Adesso sembra esser tornato tutto alla normalità! I miei amici adesso riescono ad unirsi in squadra con me.
Axel Posted September 25, 2020 Posted September 25, 2020 installed the new version but still does not work.
Axel Posted September 25, 2020 Posted September 25, 2020 A me ancora non funziona ragazzi, non so più che fare.
Administrators Netduma Fraser Posted September 26, 2020 Administrators Posted September 26, 2020 14 hours ago, mirkoG said: a meno che io non metta modalità spettatore, gli altri non riescono ad entrare nella mia squadra. lo fa anche a te? Devi aggiungere i tuoi amici all'elenco dei permessi e poi potranno giocare con te indipendentemente dalle impostazioni del filtro geografico. - You need to add your friends to your allow list and then they can play with you regardless of your Geo-Filter Settings. 13 hours ago, Axel said: installed the new version but still does not work. Do this: Turn off the console completely (no instant on/standby mode) Remove it from the Geo-Filter Flush the Geo-Filter cloud Re-add the Device Zoom out completely Set your Geo-Filter settings, make more restrictive settings - you might as well not use it at 2000km Start up the console/game If you notice anything outside the radius being blocked that is causing you to not get a game then allow it
Administrators Netduma Fraser Posted September 27, 2020 Administrators Posted September 27, 2020 12 hours ago, Axel said: log-1601162319963.txt Sorry, what is this for? Did you follow my instructions above?
Axel Posted September 27, 2020 Posted September 27, 2020 yes i followed your instructions but still keeps throwing me out of games giving me network error.
