help issue low speeds
hi there i have had my r1 one for years now.and never come across this issue. i have moved my set up from down stairs to up in my room and taken my isp,s hub up to so i am still wired. the problem i am having is i can only get around 80 meg when i have allways got the 200 on speed test.i have tested the speed on my mac wired into the hub on speed test .net on the same server and i get full speed. i carnt seem to find the problem on the r1 can anyone shed some light for me thanks
200 is about the limit that the R1 should be able to handle. Maybe it's maxxing out? What's the CPU/RAM usage at?
I once had virgin’ 360 meg and that’s what I got with the duma. So now on 200 but can’t get 90 meg on speed test .net. I can on my phone via WiFi and on my mac wired
  • 2 weeks later...
hi fraser sorry for late reply i all ways thought the duma set its self up for the speeds we put in as i have never had an issue in the past.and i dont know were Terbo mode is
If you put your bandwidth speeds in and allow it to setup up for you it will apply this automatically. Otherwise turbo mode can be found in Settings > Miscellaneous.
