I just retry to disable Smart Connect and that works perfectly when my phone is connect to 2.4GHz but when I switch my phone 5Ghz everything is bugy.
Hmm... Are you close to the router when you use 5GHz? It doesn't have a massive range in 5GHz mode.
Yes that’s work perfectly for all and I got 500 mb/s on two side
So it's working correctly now is that right? 2.4GHz is better for distance but speed is slower. 5GHz is better for speed but decreases with distance.
No I still have issues with HomeKit when my phone i connect to 5GHz but I got a strong signal (90%) but when I'm connected to 2.4GHz everything works
If the devices are connected to 2.4GHz then usually the device to control them has to be connected to the same network, does this reasoning make sense for your situation?
  • 2 weeks later...
Yes it's make sense but when i'm connected with 5GHz or 2.4GHz I'm in the same network ?
As long as the device and the phone are both on the same band. I think that's what Fraser means.
