prince-horus Posted September 27, 2019 Posted September 27, 2019 anyone can take the hand by team viewer to configure my homme network and xr500 a good time forever because it's impossible to configure without lag,please Alex can u help me
Administrators Netduma Alex Posted September 27, 2019 Administrators Posted September 27, 2019 If you let me know what problems you're having I can attempt to fix them via TeamViewer. I'll need you to give me your access code. We can talk via DMs or on Discord if you want.
prince-horus Posted September 29, 2019 Author Posted September 29, 2019 Hi Alex, thanks for your attention, when you can watch, I work all the day, perhaps the monday night a 18h30,thanks you
Administrators Netduma Alex Posted September 30, 2019 Administrators Posted September 30, 2019 Well I finish work at 18h so that's not ideal. This is why we usually don't do TeamViewer.
prince-horus Posted October 1, 2019 Author Posted October 1, 2019 Ah ok thanks you Alex for your attention to me but I've found THE connection, bye
Administrators Netduma Fraser Posted October 1, 2019 Administrators Posted October 1, 2019 6 hours ago, prince-horus said: Ah ok thanks you Alex for your attention to me but I've found THE connection, bye You've managed to resolve your issue then? Can we close this topic?
prince-horus Posted October 2, 2019 Author Posted October 2, 2019 Non en fait ça marche pas le lendemain ça refonctionne plus, je continue de demander de l'aide
DanyKTM Posted October 2, 2019 Posted October 2, 2019 moi souvent je vais relire les topics dans knowledge base et sa me fais allumer sur des points important que j'avais oublié ou changer pour fin de test Explique nous un peu quelles sont tes set-up ? modem, fillaire ou sans fil, ip fix etc etc etc.
Administrators Netduma Fraser Posted October 2, 2019 Administrators Posted October 2, 2019 What is your average ping to the game shown by the Geo-Filter? What are your speeds and what QoS settings are you using?
prince-horus Posted October 3, 2019 Author Posted October 3, 2019 Le routeur est installé via option 60 et 61 à l'ont de sfr, mon ping speedtest est de 13 ms, mon download est de 940 mbit et mon upload est de 380,la console est placé dans le serveur dmz, l'upnp allumé, le geofiltre est sur Paris avec 500 km, duma os game console, barres a 70,,share excess coché, ping en jeu de 30 à 40ms ça dépend... Lorsque je rentre en gunfight, le jeu se ralenti, l'écran se floute et je tire first, je meurs first, je mets des quantités de balle pour tuer un gars les game en one versus duo or squad me sont strictement impossible au vu de cette connexion, je joue sur ps4 pro avec écran 4k,mes câbles sont cat7, je comprend pas, merci pour votre aide
Administrators Netduma Alex Posted October 3, 2019 Administrators Posted October 3, 2019 Your settings seem ideal. I did not understand my translation perfectly, did you put your console in the Priority Traffic menu? Mes excuses pour la barrière de la langue, j'utilise google translate
prince-horus Posted October 22, 2019 Author Posted October 22, 2019 Hi Alex tell me if the 4 November you can try to configure my network I will have a holiday this day thanks
