Error messages and slow loading of dashboard and settings menus
Doughboy
Hi I have a question: how do u reset the router back to before the last update because since I’ve had it I got these errors on my geofilter screen and random errors at different screens. I tried master reset and putting in new settings but it updates the firmware to the most recent one.
You're talking about a Netgear Nighthawk Pro Gaming router right? In the firmware updates section of settings, there is an automatic updates option, and if you press I Disagree and press save, your system will remain on the version it's currently on.
You can download whichever old version you want from here (if you're on an XR500): https://www.netgear.com/support/product/XR500.aspx
When you go through the setup procedure, make sure that you refuse any updates that it finds automatically!
